BufordBoone
Platinum Member
I was practicing yesterday and spent a little time with flux core, no gas. I was using a Lincoln MP210. In the setup, you tell it what you are welding and it selects the settings. You have the ability to adjust the wire feed speed and the volts different than recommended.
I made a weld on 14ga steel and promptly burned thru. I reset the machine for 16ga steel and it worked very well. Next I tried welding a piece of 3/16" to the 14ga. It was OK but, just to see what difference it might make, I decided to turn the voltage up a small amount (I don't remember the settings, should have written them down).
The slight increase in voltage made a major improvement. Far less spatter and much smoother weld. In looking at the backside of the 14ga steel, I can see heat marks but no burn thru. I assume that means I was getting good penetration on the thin metal. Since I concentrated the heat on the thick metal and drug the puddle down onto the thin metal, I would think I also got good penetration on the thick metal.
Anyway, I've realized I don't really understand the relationship between wire feed speed and voltage for this type of welding. I'll do some research but thought I'd ask here.
I've gained a ton of knowledge from those of you here. Thanks, in advance.
