fingerless gloves
   / fingerless gloves #1
randy41
Linden VA
looks like winter is settling in and my shop where i do woodworking is not heated. any recommendations for fingerless gloves that won't cost an arm and a leg (& a finger)?
   / fingerless gloves #2
I have Youngstown gloves which work well, only the thumb and first 2 fingers of the glove are fingerless.
   / fingerless gloves #3
This may sound too simple but how about you get the pair that you like and cut the fingers off
That was easy :D
or try a motorcycle supply
Jim
   / fingerless gloves #4
That was easy :D
Jim
Now that sounds like a great idea and as stated "That was easy" :)
The Gotcha Man
   / fingerless gloves #5
I never understood them. When does the palm of your hand ever get cold? If I can do without the fingers, I can do without the whole glove.
   / fingerless gloves #6
I take a pair of good loose fitting warm finger gloves and slice the finger on the glove I want to be open. Then I can flap the glove back to expose a finger when necessary and get it back under cover. Useful for shooting, nut/bolt issues, picking up dropped pins, picking your nose, opening a lock, running the phone, whatever.
   / fingerless gloves
good recommendation MikePA.
i don't want to ruin whole gloves I like by cutting them up.
   / fingerless gloves
thats what i ordered but i ordered directly from youngstown equipment and they are $8.95 plus $4.95 shipping.
   / fingerless gloves #10
I'm with you. Apparently certain people doing certain things in certain climates have a use for them, but I never had a use, nor can I imagine ever having a use, for fingerless gloves.
(INOP) 1998 FREIGHTLINER FL70 DUMP TRUCK (A51406)
(INOP) 1998...
2016 CATERPILLAR 259D SKID STEER (A52705)
2016 CATERPILLAR...
2017 Bomag BW90 AD-5 Vibratory Articulating Tandem Smooth Drum Roller (A55787)
2017 Bomag BW90...
2008 GMC C5 (A53422)
UNUSED WOLVERINE TQH-26-02C CLASS 1 QUICK HITCH (A54757)
UNUSED WOLVERINE...
UNUSED RAYTREE RMBD72 - 72" HYD DRUM MULCHER (A54757)
UNUSED RAYTREE...
