Finish mower leaking oil.
   / Finish mower leaking oil. #1
Darrenone
Tully, NY
Kabota L3130
My mower is leaking oil out the bottom where the pulleys are. Does anyone have any ideals how I can fix this?
   / Finish mower leaking oil. #2
Take the gearbox apart. Put new bearings and seals in were needed. Adjust bearings properly reassemble and fill with oil.
Thanks, is taking the gearbox apart pretty straight forward? And are parts and seals fairly easy to get?
Darren
   / Finish mower leaking oil. #4
The next 4 days are real busy and I won't be home so I won't be able to take the time to give you a detailed answer. In the meantime yes the gearbox is easy to take apart so take it off if you want and clean up the outside. Look for a manufacturing tag or imprint on the gearbox. You can start taking it apart if you want and I'll catch up with you around Tuesday or so. I'll be on again tonite also but only for a short time.
Again thanks. I probably won't get to it until next week anyway as it is a low priority right now as the ground is still covered with snow.
   / Finish mower leaking oil. #6
You may not need anything but a new oil seal. It should be available at wherever you bought your mower. Once you get the oil seal out, see if the bearing have any adjustment. Loose bearings may be the reason the seal went bad. Caution: don't tighten them TOO much as it will cause overheating and ruin them, a little loose is better than too tight.
If you cant get the seal out, just remove the gear box, take to your tractor dealer (or mower dealer) and they should be able to put in new seal and any other needed parts.
Thanks Gary, I think next week I will take it off mower and see if I can take it apart. If it looks like I can't do it I will take it to the dealer.
How do I get the big pulley off so that I can pull the gearbox off?
What would be the next step to fix this leak? Take it in to the dealer?
2013 Nissan Pathfinder SUV (A46684)
2013 Nissan...
2014 Mack CXU613 T/A Day Cab Truck Tractor (A46683)
2014 Mack CXU613...
Skidloader Trailer Mover (A47809)
Skidloader Trailer...
1995 CLEMENT LC9L 48FT ROLL OFF TRAILER (A45677)
1995 CLEMENT LC9L...
2022 Peterbilt 337 Single Axle Dump Truck (A45336)
2022 Peterbilt 337...
2016 FREIGHTLINER CASCADIA DAY CAB TRACTOR (A45677)
2016 FREIGHTLINER...
