Finish Mowers
   / Finish Mowers #11
Bush Hog makes a 7 foot dual bladed rotary cutter you might want to look at. Its rated at minimum 25pto hp.
   / Finish Mowers #12
Johnagain said:
I can't run a bigger rotary cutter with my JD 4310 (27 pto hp.) I figure if I can run the same ground speed with the RFM as with my rotary cutter then I should save about 2-3 hours.
Look at a pull behind cutter. They take a bit less PTO HP. You might be able to go up another 12" in width.
   / Finish Mowers
Thanks everyone for the input. I went out and bought the Landpride FDR2584 mower. I have used it on my own property of 5 acres just to try it out and it's way to big for my place (to many obsticles). I then tried it on a neighbor's 5 acre horse pasture that hasn't been cut at all this year and it worked great. It saved about 1/2 hour to cut it over the 5 ft rotary cutter, and left it with a much nicer cut. Now I'll have to come up with new $ rates to charge people.
The only problem is that the top link won't work with the JD Imatch. I will be using chains to hoist the rear off the ground to transport.
   / Finish Mowers #14
Don't buy a INLAND nothing wrong with the mower but wheels are too small and they dig in the ground too much ,Farm king next time.
   / Finish Mowers #15
I am looking @ a land-pride fdr16-60 inch. Any one have this machine, I am looking @ picking it up tommorrow .. this will be used several times a month on 3 acres with St. Augistine grass. with a TC-30..thanks jb
   / Finish Mowers #17
I bought a used Land Pride 7ft finish mower a few months ago for $600 from a client. I fixed their three way light switches and told them not to worry about paying me for it as I was only there half an hour. They asked if I'd needed a mower. hahaha After finding out that it was just sitting there with two flat tires, but in perfect condition, I jumped on it. They hadn't used it in years and wanted the space in the barn. It even has a slip clutch.
My tractor is 4 wheel drive and has 35 hp at the engine. Nothing fancy, but it pulls the finish mower allot easier then my 6 foot shredder. I mow once a month here in East Texas where hay farmers can get three cutting a year. I mow Bahia, Bermuda, Johnson, Dalas grass all mixed together with all sorts of weeds. The blades are on the dull side, but it cuts it beautifully!!!!!
There are a few areas that the grass is extremely heavy and I'll go over it twice just to get everything perfect. In the thinner or lower areas, I can cruise through it twice as fast as I was with the shredder. I think the guild wheels are what make the biggest difference. The tractor isn't lifting anything, it's just pulling the mower.
I've found that with less weight on the rear end, I can get through softer dirt and I also don't leave as many ruts or tear up the ground as much. The biggest difference is along the banks of my lake and pond. I can get closer to the water and keep on going with the finish mowere in areas that I got stuck with the shredder.
Eddie
   / Finish Mowers #18
Where are you getting those prices? Here in Alabama fdr2584 is quoted to me at $3750.00-$3900.00. Your price must be for used landpride mower.
   / Finish Mowers #19
This is a 2007 thread, those are 2007 prices.
//greg//
2011 FORD F-250 Crew Cab 4X4 Pickup Truck (A53422)
2011 FORD F-250...
2022 Padget Morris Electric Mobility Scooter (A54815)
2022 Padget Morris...
TRASH TRAILER 16 T/A (A52472)
TRASH TRAILER 16...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2019 FREIGHTLINER...
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A54814)
2003 Pierce Tilt...
2007 Yamaha Rhino 660 (A55218)
2007 Yamaha Rhino...
