kingoflawns, </font><font color="blue" class="small">( #1 do the mulching blades work well on these mowers )</font> <font color="blue"> </font> Mulching blades will work if the mower is baffled, If it is all open underneath you won't get full value from them.
</font><font color="blue" class="small">( #2 does the rear discharge disperse the clippings better than the side discharge? )</font> <font color="blue"> </font> As long as both are tested in the same enivroment ie: dry grass not too tall,not too damp, The rear should give a little better distribution. If the grass is tall and damp you probably wouldn't get much if any better cut..
For example , My neighbor has a 5' rear discharge and he almost always mows late in the day/evening so his yard looks nasty with clumps and spalling.. I try to never mow when the dew is about rise and when using the RFM side discharge with no baffles my mowing job looked great compared...But really there are so many variables to this kind of debate...
I will tell you this my 6' side discharge came with my used tractor so thats what I use, If I was buying new I would probably get a rear discharge if for only one reason, being able to mow up close on both sides of the tractor. When mowing an appreciable size lawn time will become a factor, so if you have to turn around to make another pass the opposite direction to get close ,that takes more time than just getting closer to the other side on your last pass...
That was a little more than two cents worth /forums/images/graemlins/blush.gif
