firewood pallets
/ firewood pallets #1
billbill1
Lecompton, Kansas
2016 Mahindra 1533 Shuttle AgKing 2840 shuttle shift
check this out.
/ firewood pallets #2
I had something similar which I really liked, but had to stop using it. /forums/images/graemlins/frown.gif
My tractor with R-1 tires was destroying the lawn when the ground wasn't frozen but I still needed firewood. /forums/images/graemlins/mad.gif
/ firewood pallets
I got tired of posting and typing cuz I couldn't get the picture to take. AndyM showed his cut list for these pallets and I changed to something that I think will work better for me. I don't wat to stack these pallets together-allowing me to round the wood over the top rail. I cut, split, and stack the wood on the pallets, let it cure a season, carry it to my force air wood furnace in my attached garage, and burn right off of the pallet. The pallet takes a cut list of 2 each 44-3/4" by 8 each 40" with 3 screws at each connection, 36 screws per pallet. By not stacking, 1 X 6's in CCA will be strong enough to keep the wood on the pallet. I use the KK carry-all to move the pallets (from the short side=on the 3ph) and pallet forks on the front to move two pallets from the timber at once. 3 pallets are around a cord so I'm going with 12 to 16 pallets to start with. Thank you AndyM for saving my back.
/ firewood pallets #4
Great idea, Iam going to find some pallets in the morning, thanks /forums/images/graemlins/smile.gif
/ firewood pallets #5
Ah ha! You have found a way to help prevent "jumpers"! /forums/images/graemlins/tongue.gif
/ firewood pallets #6
Nice to see that someone found a good use for those darn "CHEP" pallets. We get stacks of those things at our warehouse and the freight companies won't take them in pallet exchange because of that blue paint. They are the best made pallets I've seen, but because of their proprietary deals with shippers, only Chep authorized haulers will move the pallets. Personally, I've cut them down and used them for storing various items off the ground, I've also traded them to a machine shop that uses them to hold steel. In exchange, they've welded up plenty of things for me and for our truck fleet. We get such big piles of those pallets that the fire inspector has warned us that piling them up outside is a bonfire waiting to happen, but I sure don't have room inside to store dozens of stacks of pallets! One thing I can tell you is that those pallets will last you for a very long time hauling wood because they are so sturdily built.
/ firewood pallets #7
</font><font color="blue" class="small">( We get such big piles of those pallets that the fire inspector has warned us that piling them up outside is a bonfire waiting to happen )</font>
Bob
What's the issue there? A couple lawn chairs, a cooler of beverages and a gallon of diesel and you're all set. /forums/images/graemlins/grin.gif
I have found out that they do get a bit warm though. I actually burnt the bark clear off trees that were a little too close. /forums/images/graemlins/crazy.gif
/ firewood pallets
The best thing about the Chep pallets is the opening is the same from both sides, allowing the use of the carry-all for transporting.
/ firewood pallets #9
Bob
Isn't the CHEP pallet a re-cycling scheme, and there would be a deposit that could be claimed on each one returned? But if truckers won't take them, then the re-cycling system falls apart somehow.
According the the Brambles website, WalMart, HomeDepot, Sysco, and others have contracted with them and I would think would pay something to get them back into the system.
Interesting.
/ firewood pallets #10
I'd love to find some more of those Chep (blue) pallets. I have pallet racks in my barn and I use my forklift to store all sorts of stuff there. (read between the lines - I need a bigger barn) They seem to be fairly sturdy pallets.
/ firewood pallets #11
Bob,
If your warehouse has a lot of idle wood pallets, some things to keep in mind. The following is from NFPA 13, 2002 edition which is the standard most fire departments use.
Idle pallet storage introduces a severe fire condition. Stacking idle pallets in piles is the best arrangement of combustibles to promote rapid spread of fire, heat release, and complete combustion. After pallets are used for a short time in warehouses, they dry out and edges become frayed and splintered. In this condition they are subject to easy ignition from a small ignition source. Again, high piling increases considerably both the challenge to sprinklers and the probability of involving a large number of pallets when fire occurs. Therefore, it is preferable to store pallets outdoors where possible.
A fire in stacks of idle plastic or wooden pallets is one of the greatest challenges to sprinklers. The undersides of the pallets create a dry area on which a fire can grow and expand to other dry or partially wet areas. This process of jumping to other dry, closely located, parallel, combustible surfaces continues until the fire bursts through the top of the stack. Once this happens, very little water is able to reach the base of the fire. The only practical method of stopping a fire in a large concentration of pallets with ceiling sprinklers is by means of prewetting. In high stacks, this cannot be done without abnormally high water supplies. The storage of empty wood pallets should not be permitted in an unsprinklered warehouse containing other storage.
If pallets are stored inside they should be limited to the following, unless the sprinkler system is designed for the height of storage of pallets.
1.Pallets shall be stored no higher than 6 ft (1.8 m).
2. Each pallet pile of no more than four stacks shall be separated from other pallet piles by at least 8 ft (1.4 m) of clear space or 25 ft (7.6 m) of commodity.
I have attached a table for how far wood pallets need to be stored away from a building.
If you have or are considering plastic pallets, review the info below:
12.1.9.2.2 Plastic pallets where stored indoors shall be protected as follows:
(1) Where stored in cutoff rooms the following shall apply:
(a) The cutoff rooms shall have at least one exterior wall.
(b) The plastic pallet storage shall be separated from the remainder of the building by 3 hour–rated fire walls.
(c) Sprinkler protection by one of the following:
i. The storage shall be protected by sprinklers designed to deliver 0.6 gpm/ft2 (24.5 mm/min) for the entire room or by high-expansion foam and sprinklers as indicated in 12.1.11.
ii. K-14 ESFR upright sprinklers when the storage is on floor and the system is designed to supply all sprinklers in the room at 50 psi (3.4 bar) for a maximum of 30 ft (9.1 m) ceiling or 75 psi (5.2 bar) for a maximum 35 ft (10.7 m) ceiling.
(d) The storage shall be piled no higher than 12 ft (3.7 m).
(e) Any steel columns shall be protected by 1-hour fireproofing or a sidewall sprinkler directed to one side of the column at the top or at the 15-ft (4.6-m) level, whichever is lower. Flow from these sprinklers shall be permitted to be omitted from the sprinkler system demand for hydraulic calculations.
(2)Where stored without cutoffs from other storage the following shall apply:
(a) Plastic pallet storage shall be piled no higher than 4 ft (1.2 m).
(b) Sprinkler protection shall employ high temperature–rated sprinklers.
(c) Each pallet pile of no more than two stacks shall be separated from other pallet piles by at least 8 ft (2.4 m) of clear space or 25 ft (7.6 m) of stored commodity.
  • 554090-outside storage of pallets.pdf
/ firewood pallets #12
Most of our pallets are are traded in & out when freight companies deliver goods to us. Damaged and substandard pallets are set outside, about 200' from our building, we have a service that comes and picks them up (and pays us) for those pallets.
Then we have the blue CHEP pallets that BillBill used. Nobody but CHEP will come pick those up. No traditional pallet exchange is allowed by the common carriers. So we also store those outside, again a couple hundred feet from the building. And they are kept away from the other pallets. Some of the stacks are probably as high as 12' tall, but most are in the 9' to 10' range. I hate those things because of the segregation issues. To be blunt, if they were to go up in flames 10 minutes before the truck came to collect them I would go get some sticks and marshmallows and if I was especially crabby that day I might even lock the property gates to slow down the fire department response! Chep is a PITA and they can keep their pallets! The less I have to deal with them, the less it costs me. If people want their goods delivered to stores cheaper, then they would not buy goods that are shipped on Chep pallets, but since the Chep pallet inventory ends at warehouses like mine, no consumer knows what items cost us more to handle and what cost us less.
/ firewood pallets #13
Tom: that's a pretty thorough response there. Your attachment is the thing interesting me at the moment, it crashed my computer in a way I've never seen before. What is it? Maybe a link to NFPA? Might have a login involved. SteveV /forums/images/graemlins/crazy.gif
/ firewood pallets #14
</font><font color="blue" class="small">( Your attachment is the thing interesting me at the moment, it crashed my computer in a way I've never seen before. What is it? Maybe a link to NFPA? Might have a login involved. SteveV )</font>
Steve, it's just a simple PDF file that can be read if you have Adobe Acrobat Reader. If you don't have it on your computer, click here to download.
Adobe Reader
/ firewood pallets #15
Steve,
As John said it is just a pdf file. I hope you were able to recover all your files. The file is a table from NFPA as to how far wood pallets have to be from a building based on the construction of the building.
/ firewood pallets #16
Looks great Bill.
How did a post on storing firewood turn into another unrelated saftey meeting? I am supposed to be on vacation!!
/ firewood pallets #17
Thanks for the response; it is sssslightly possible I may be running the Mozzilla V9 just a little tooooo stripped down, but that was the reason I asked. Acro 5 probably didn't help either. Both at least one rev old. SteveV /forums/images/graemlins/tongue.gif
/ firewood pallets #18
Nice setup!! /forums/images/graemlins/smile.gif Definitely makes it easy to move wood closer to the house when needed...............J
/ firewood pallets
It works great for me, hopefully it will help some of you out too. The cut list will change with 1" lumber, you will need to gain 1-1/2" on the side pieces. Happy New Year to all!!!!!!
/ firewood pallets #20
Hello All,
This is just what I was thinking of building this winter. I piled up firewood near my pole barn and would like to move it out away from the buildings. Then just bring it back with my Kubota when I need it.
I may just copy your design!
ksmmoto
2016 Caterpillar 349FL Hydraulic Excavator (A56857)
2016 Caterpillar...
Screen USA TROM 6090 Trommel Screener (A61572)
Screen USA TROM...
2011 Peterbilt 365 Altec AC38-127S 38 Ton Straight Boom Crane Truck (A61568)
2011 Peterbilt 365...
2020 KENWORTH T680 6X4 T/A  SLEEPER  TRUCK TRACTOR (A59910)
2020 KENWORTH T680...
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
Fork Extensions (A61572)
Fork Extensions...
