First Gen TC21D Alternate Front Axle Seal PN Inside
   / First Gen TC21D Alternate Front Axle Seal PN Inside #1
deltatango
King George, VA
NH TC21
TLDR - The Chevy Aveo 05-11 Automatic transmission seal will work as a replacement in a pinch for a temp fix, PN 223830 or SKF 14720.
Hi all, This weekend my TC21D blew the front seal in the final drive at the steering knuckle. I thought I had the correct seal to replace it, but it turns out I bought the seal for the second generation of TC21D. The shaft ID of the second gen is slightly smaller....so the seal I bought was too small.
Knowing my beautiful bride would throw me out if I bled hydro fluid back across the driveway a second time...I needed a solution today. Internet search revealed that the Chevey Aveo seal matched the SBA050600038 dimensions. Its not nearly as good of a seal WRT dirt tolerance or contact area, but if you need a quick cheap fix while waiting for your CNH part to arrive its a viable option.
Kimball Midwest Wire Cabinet w/Wire (A59076)
Kimball Midwest...
LOT: (1) Craftsman Shop Vac, (1) Dewalt Shop Vac (A59076)
LOT: (1) Craftsman...
EVINRUDE OUTBOARD MOTOR (A58374)
EVINRUDE OUTBOARD...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
2023 CHEVROLET 4500HD CAB AND CHASSIS (A58017)
2023 CHEVROLET...
2019 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A55973)
2019 Freightliner...
