Oil & Fuel First hydraulic oil change?
   / First hydraulic oil change? #21
Thanks, TSC has it on sale now. I only need 4gal so the tub would be a waste.
Traveller Universal Tractor Trans/Hydraulic Fluid, 2 gal
$11.99 Was $14.99 Save $3.00
-R
They sell it by the gallon too but it's not a bad idea to have an extra gallon or so on hand to make up for spills, leaky couplers etc.
   / First hydraulic oil change? #22
I'd like to see tractor manufacturers find out a way to eliminate this quite troublesome thing and waste of huge amounts of oil. Cars and trucks used to require oil and filter changes after only (around) 1,000 miles or so. Now, they typically allow you to go to the routine 7.5-15k oil change interval the 1st time.
Reasons are as given above by others, but I'd think they should find out a way to blow out or flush out these metal particles and shavings at the factory where it could really be better controlled and checked.
I just did a complete service for a customer on a L2500 Kubota. '98 model, had never been serviced. 675 hours on the clock. The factory synthetic hydraulic oil was pristine. Zero shavings on the magnetic plugs. This model has the screen in the rear axle casing. I could not reuse it. Not sure if it was deformed from the factory or due to restricted flow. Did not appear to have any shavings or grit on it. Because I was replacing it I did not spend any time cleaning it. Radiator and front axle pristine as well. The engine oil was used. Not clear if it was original or not. Her husband had passed and she was not sure. With a new battery, belt, fluids and filters, she came out of her year and 1/2 slumber and purred like a kitten.
Changing fluids is just something that has to be done when you are under warranty. Even if it is overkill.
   / First hydraulic oil change? #23
How much hyd fluid does it take to do a change on the 3016 hst ?
   / First hydraulic oil change? #24
Did the 50 hour on my emax22 found metal filings on the hydro drain plug magnet.
   / First hydraulic oil change? #25
Not uncommon for the first change; when I did the first change on my JD 2320 there was a good bit of shavings on it. The second time there was barely anything on it.
   / First hydraulic oil change? #26
It's normal for a little fuzz to be on the magnet picked up from the oil for a new piece of gear but after the gears and bearings have lapped themselves in, the fuzz should go away.
   / First hydraulic oil change? #27
I know I am getting less and less fuzz as I age........ at least in spots I am supposed to have fuzz... :)
   / First hydraulic oil change? #28
Very basic science.....duh. Gravity! Slowly drifts from the head to the ears, nose etc. Hahaha
   / First hydraulic oil change? #29
In case someone else need this info I was told it's 9 gal for the 3016
   / First hydraulic oil change? #30
If anything I'm getting more fuzz in wierd places where there didn't use to be any.
(INOP) 2019 CATERPILLAR 336 EXCAVATOR (A51246)
(INOP) 2019...
2021 Kubota RTV-X1140RL-A (A47384)
2021 Kubota...
New/Unused 12ft x 7.4ft x 8.2ft Container (A51573)
New/Unused 12ft x...
JOHN DEERE XUV835M LOT NUMBER 26 (A53084)
JOHN DEERE XUV835M...
KODIAK 10' HD ROTARY MOWER (A51406)
KODIAK 10' HD...
2009 Freightliner Columbia 120 Winch Truck, VIN # 1FUBA5CK39DAM2731 (A51572)
2009 Freightliner...
