KentT
Elite Member
- Joined
- Mar 31, 2005
- Messages
- 2,928
- Location
- Sevierville, TN
- Tractor
- 1993 Power Trac 1430 w/Kubota diesel engine
I spent about 2.5 hours with the minihoe today, after I'd changed the hydraulic oil to AMSOIL 20W50. My first impression is that there is a noticeable difference when its hot -- not an incredible difference, but still a significant one.
I was taking advantage of a very dry summer, digging a deeper drainage ditch in a mucky spot that typically has running water. The new ditch is 2.5ft - 3ft deep, and I'm hoping to lower the water table enough there so that the area will firm up. I was working in a thick muck that I'd churned up with the tires that was over 6" deep in spots -- so sticky/mucky that I had to stop several times and use a stick to clean out the bucket, since jarring it wouldn't dislodge it. Because I couldn't straddle the ditch line, I had to drive up to it, dig out a bucketfull, back out and dump it, then drive back up. All this driving in it churned up a mess...
I never had ANY torque problems at all, and could still occasionally spin a tire even after 2-plus hours of use. No PT waggle needed -- just find the correct treadle position and it would slowly pull itself out of any condition -- I was dragging the belly-pan of the tractor fairly often. In comparison, last weekend I worked in there briefly with the grapple bucket, skimming off the fallen limbs and leaves. Twice I was mired down -- not even to the belly-pan, like today -- and had to "waggle" my way out -- I was just about ready to get the come-along. The wheelmotors would just whine then -- no spinning -- and just sit there. Not today -- even dragging the belly-pan, I was never in a position that I had to waggle to get out of...
So, my first impression is that it was $200 well spent.... I certainly can't tell what cold-weather starting will be like, since the heat index was well over 100 degrees today. /forums/images/graemlins/laugh.gif
