First outing with cutter
   / First outing with cutter
Thanks all! I did the following:
Adjusted my top arm of 3 pt so that the rear of my cutter was about 3-4 inches higher than the front. Now when I raise the cutter with the 3 pt so the front is 2-3 inches off the ground, the rear is 5-6 inches. I then lowered the tail wheel so that when the cutter is in this position, the tail wheel is in solid contact with the ground.
Making these adjustments also resulted in the cutter being raised much higher when the 3 pt was lifted and the back was even higher that the front in the raised position.
I realize I was set to cut way too low - scalping as someone else suggested. I think I have things adjusted much better now and will try to make it back out one afternoon this week to give it another go. Hopefully, I didn't do too much damage to the cutter by running it this way. Live and learn, I guess.
A friend from work came by this afternoon to listen to the cutter. He said that it sounds perfectly normal. Like I said before - I've never been around one and guess I was being a little too paranoid.
I do remember once yesterday that the cutter was really vibrating - even more that 'usual'. I discovered that one blade had gotten wedged under the other and the whole mower was off balance. I was able to separate the blades and my friend told me that spraying the blades with WD-40 might help keep them from becoming wedged again.
Anyway, thanks again for all your help. More will be needed later I'm sure...
   / First outing with cutter #12
You might want to look into a set of check chains as well. They will keep the front of the cutter at the same height and you wouldn't have to worry about the front sagging as you cut. Once they are set... lower the 3pt all the way down and away you go. They are an easy fix to keep the cutter at the same height all the time and it takes the weight off the hydraulics. And if you wanted to lower or raise your setting.... it is as simple as adjusting out or in a link of chain. (For big adjustments in cutting height you might need to adjust the tailwheel also)
2018 CATERPILLAR 259D SKID STEER (A51242)
2018 CATERPILLAR...
2021 FORD F-150XL CREW CAB TRUCK (A51406)
2021 FORD F-150XL...
2019 John Deere 8295R MFWD Tractor (A50657)
2019 John Deere...
Portable Cattle Loading Shute (A50515)
Portable Cattle...
2015 FREIGHTLINER CASCADIA DAY CAB (A51222)
2015 FREIGHTLINER...
2020 CATERPILLAR 259D3 SKID STEER (A51242)
2020 CATERPILLAR...
