First time drilling post holes
   / First time drilling post holes #31
We welded a 'wiper' blade (iron strap) on ours to throw the dirt away when the auger bottoms out. helps on dry dirt. With moist dirt, we dont have to clean holes.
   / First time drilling post holes #32
You'd rather dig post holes by hand than back the auger out ever once in a great while? You have better shoulders than me. :D
My shoulders are crap, so I'll either rent one or hire it done the next time I need a hole drilled.
-I didn't mean YOUR tractor, ole farmerbuck, I meant the OP!
I see now it is a JD 4300, with 27 PTO HP. That should be enough to handle a 9" auger, but I'll defer to your experience; you have drilled a lot more holes in the planet than me:thumbsup:
When I had my PHD, it had a 12" auger on it and my 4200 handled it fine. I think my PTO HP is 20 - 21.
   / First time drilling post holes #33
Can you explain that? Unless your PHD has some sort of magic feature to prevent dirt from falling back in the hole when you lift the auger out, I can't visualize not having to clean the bottom of the hole.
The MAGIC feature is the ability to dig a deeper hole than what you will get with a rear mount phd. I want my corners 5' deep and the rear will not go that deep clean. I can go over 15' and drill a 24" pier hole for foundations. All I was saying is that the front mount works out much better because of down pressure and clearance. It's also safer than pulling or hanging on a rear mount.
   / First time drilling post holes #34
So you're setting a post on loose dirt? I guess I just don't like the idea, though I can't say for sure it's bad.
Not sure why anyone would be hanging or pulling on a PHD? That certainly wouldn't be safe, but I've never seen the need.
   / First time drilling post holes #35
So you are saying that you have never drilled a hole that the weight of the phd alone was enough for the bit to bite and dig to full depth? You must have pure sand. I feel like I am arguing with a professor who speaks in hypotheticals and has never actually done what he is arguing about. Almost all around here who dig post or pier holes for a living use skid steer loaders for the same reasons I listed for using the front of the tractor.
   / First time drilling post holes #36
Aggie is your hydraulic phd a high-flow skid steer style?? I don't imagine my 4300 would output enough hydraulics to run one of those... I have access to one, but it is skid-steer style attach also. just wishing it would work...
   / First time drilling post holes #37
Seems you're the only one arguing. I was simlpy asking a question. I'm not sure, but I think you worded your question wrong. I'm saying that the PHD digger does fine without my help pushing or pulling unless I hit rock. Then, nothing is going to help. If the PHD stops digging for whatever reason, a very slight adjustment in angle (move forward or backwards SLIGHTLY) does the trick every time. I have no sand at all. Soil varies from heavy clay to shale. I've dug plenty of holes, not sure why you think that just because you can't do something that no one can.
   / First time drilling post holes #38
So it is bad to have a small amount of loose dirt in the bottom of the hole when the post is set, but ok to wallow out the hole?
   / First time drilling post holes #39
Not all skid steers are high flow. Mine is primarily used on a skid steer, but works fine on my tractor. It doesn't spin near as fast as the pto style, but doesn't need to since it doesn't grind its way to the bottom. I do have skid steer fittings on the front though.
   / First time drilling post holes #40
AGGIE00,
Are you using a skidsteer or a tractor with ssqa?
I considered the front mount hydraulic auger setup and rented one to use on a job but found it necessary to have a spotter since the auger was directly ahead of the tractor cowling. So I went with a rear mounting on my backhoe which makes it easy to see and control.
Much more reach than a fel mounted unit too.
2016 Hitachi XZ300LC-6 (A47477)
2016 Hitachi...
JLG 1255 Telehandler (A55218)
JLG 1255...
Adams 5 Ton HC Spreader (A55301)
Adams 5 Ton HC...
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A54757)
UNUSED WOLVERINE...
UNUSED SDLANCH SDLC2030FT ALL STEEL CARPORT (A54757)
UNUSED SDLANCH...
2006 KOMATSU WA200-5 WHEEL LOADER (A52705)
2006 KOMATSU...
