First tractor advice
   / First tractor advice
I would guess at about 15 to 20 degree hill to climb. Trailer just an old bunk boat trailer. I dont have weights.
I replied to fast by mistake. I'm actually at the dealer now looking. Lots of nicer big stuff but way out of my price range. Hauling wood out is not the main job of this tractor. Just something that would be nice to do as well as the other stuff. It's small enough to trailer as well. Maybe I'll keep looking or wait another year or 2
   / First tractor advice #13
I'm not familiar with TYM, but I suspect you should be looking a little larger. Around 35 hp maybe.
I have a Kioti 3510, with the 3 range HST. It seems about perfect for 98% of what I need it for. Firewood, mowing, loader work and some tilling on 20 acres. I have one steep hill, the road has a switchback and the last bit is close to 18-20% grade. It does okay in mid range with no load, need to be in low range if pulling anything over 600 lbs. 4x4 necessary. Side slopes are sketchy. It doesn't take much to start sliding with a tip over soon after that.
I filled my rear tires with water, it doesn't really freeze here. That added about 460 lbs total. Definitely makes it feel more stable but I still wouldn't push it on much of a side slope. All it takes it a hole big enough for a tire to drop into or a rock the size of a softball and you are going over.
   / First tractor advice #14
Going between trees and being able to navigate your property is definitely something to consider. My dad bought a commercial grade mower and couldn't get to half of the lawn because the deck just wouldn't fit.
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
33ft Dovetail Flatbed Trailer (A55315)
33ft Dovetail...
40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
40ft T/A Gooseneck...
PENDING SELLER CONFIRMATIONS (A57880)
PENDING SELLER...
2020 Chevy Silverado (A55315)
2020 Chevy...
fire truck 2007 (A56858)
fire truck 2007...
