First you need to think like me.....
   / First you need to think like me..... #1
wroughtn_harv
Super Member
Denison, Texas
2013 Volvo MC85C
Have you ever used a set of manual post hole diggers and found it very frustrating when the hole is deeper than two feet and you can't get them to close because the handles hit the sides of the hole?
I look at manual post hole diggers different from ya'll. If the digging isn't super hard I won't pull out a power unit if there is less than ten holes most days. I can hand dig that many holes with about the same effort as unloading the hydraulic Beaver and digging the holes and then putting it away.
Now my diggers are all steel. I use the blue all steel clay diggers you buy at professional dealers. Even my diggers like you get at the box stores have had the fiberglass or wood handles tossed and they've received pipe handles. I like them to have some weight. They dig better.
When I dig with the power auger I still come back and finish clean the holes with the hand diggers. I like a clean hole for my concrete and post.
One of my peeves has been the problem with the handles restricting ability to clean holes effectively. I figured there had to be a better way.
Then you need some pipe and one of these....
And it really helps if you have one of these...
When you're done with the heating and hammering you grab a pair of digger buckets that have been taking up space and glue them on to your handiwork
Another view....
Now look at the last two pictures.
Get it?
It is so slick it makes WD40 look like glue.
   / First you need to think like me..... #7
OK...I'll ask the tough question...
Where'd the chicken go? /forums/images/graemlins/laugh.gif
Sometimes it takes her less time than others to do her thing. Day before yesterday it took her no time at all.
Actually it's a time share. I own it. When she uses it she leaves an egg as rent.
   / First you need to think like me..... #9
Makes you wonder why it wasn't designed it that way in the first place!
John
   / First you need to think like me..... #10
Never seen a "backward" post hole digger before /forums/images/graemlins/wink.gif - good idea, but I've had more experience than I ever wanted with the regular ones. /forums/images/graemlins/frown.gif
2025 K2223 UNUSED Double Garage Metal Shed (A50860)
2025 K2223 UNUSED...
2016 Toro Groundsmaster 3505D 72in Rotary Mower (A48082)
2016 Toro...
2006 Peterbilt 335 Day Cab Truck (A50860)
2006 Peterbilt 335...
Ferris IS2100Z Zero Turn Mower (A50860)
Ferris IS2100Z...
2009 Ford Fusion SE Sedan (A48082)
2009 Ford Fusion...
2014 PETERSON 4700B HORIZONTAL GRINDER (A51242)
2014 PETERSON...
