fix-a-flat?
   / fix-a-flat? #11
I had a constant nagging front flat due to a slow leak on my BX2200. I put a new valve in (it semed to be leaking slowly from there, but no luck. I would run the FEL for a half day and then have to put air in the tire. My neighbor with 2 tractors said just ge some slime (which I did) and put the whole can in there (which I did).
It has been fine since - Actually it seems to work great. I have moved a lot of topsoil since then and yes it is a lot of weight on the fronts, but you have to make sure you really have a lot of weight in the back, as it really helps take some of the load from the front.
2013 KENWORTH T800 DAY CAB (A54607)
2013 KENWORTH T800...
CUTTING TORCH (A53843)
2018 CATERPILLAR 815K LANDFILL COMPACTOR (A52705)
2018 CATERPILLAR...
2016 CAT 325FL CR (A47477)
2016 CAT 325FL CR...
2022 DRAGON 130BBL VACUUM TRAILER (A53843)
2022 DRAGON 130BBL...
2012 KENWORTH T800(INOPERABLE) (A53843)
2012 KENWORTH...
