Fixing a Lawn Problem - Compost Maybe?
   / Fixing a Lawn Problem - Compost Maybe?
Based on everyone's responses I decided to get some compost + Loam and spread it 1 - 2" deep over the lawn. The soil there now is sand, it actually blows away and cracks when its dry, so that's almost certainly the problem. Once I get it all spread I'll test a sample and then fertilize or put other additives as needed. It seems to be very nice stuff, I spread 15 yards today and will do the other half tomorrow and then spread some seed. If I get a chance I'll post a few pictures.
   / Fixing a Lawn Problem - Compost Maybe? #12
I'll keep watchin your results. Good Luck!!
Eddie
   / Fixing a Lawn Problem - Compost Maybe? #13
Excellent info in posts #8 & #9. Good compost isn't fully broken down but needs the process to continue. Applied in spring, it can be difficult to keep action going when it dries out for summer. I wouldn't just top dress, but disc/drag it in to prevent a 'barrier line' between new/existing bases.
Two biggest mowing mistakes are cutting too short and not regularly enuf, not that the OP is one of them. When we cut 'down to brown' at long intervals different species race to recover their 'green' at different rates, so mowing 'long'-ish and on a schedule should keep height more even between cuttings. Bare spots fill in quicker and weeds are choked out. Soil is shielded/shaded from evaporation, sun-baked ground. Insects and wind-blown seed (weeds) will be somewhat taken care of by insects vs turf digging vermin or moles that feed on grubs more easily laid in exposed soil. Best mowing practice reduces other chores, period. (patching, watering, spraying).
We transplant shrubs/trees best during a month with an 'r' in it, so fall planting/overseeding has the best chance of success due to lowered watering reqs and more time to establish root system before a dry season. Don't ever bag unless needed to mulch raised beds, etc. Turf will build over successive seasons as clippings add compostable fodder and further shield soil. ("Mistakes will really set you back.") Fertilizer is useless unless proper Ph allows nitrogen absorption. Beer/water mix in spray tank will break thatch down in moist springtime conditions vs raking. 'Cool season' grasses (blues, ryes, fescues) will grow either roots or blades according to nitrogen access, light, and temps above freezing.
btw: Grass is easy on my sand dune in central MI, and foods plots here are tough by comparison. Recovering the worst areas (~1/2 ac sections) begins with spot spraying, frequent light fertilizer apps in spring/fall (minimizes soak-thru, waste, runoff into pond) until turf builds up. Seed/overseed in the fall and water-in to establish soil contact. btw: 'Contractor' mixes exceed because they blend durable 'bunch'-types with rhizomes that fill in weak spots and gradually replace quick-starting 'annuals' in the mix. Sure helps not to over-think it.
Just an update in case someone finds this via search or was curious. I spread 3 - 6" of composted loam over the lawn areas that weren't doing well and reseeded. It appears to have come in very nicely and the new soil is far better. I'm not getting any stratification issues and the soil is handling the huge amounts of rain we've been getting much better. It appears that my original issue was caused by soil without enough organic matter, which would dry out quickly
New Holland TS 75 Front Loader Utility Tractor (A53421)
New Holland TS 75...
2017 Chevrolet Tahoe SUV (A55853)
2017 Chevrolet...
2016 Volkswagen Jetta Sedan (A55853)
2016 Volkswagen...
2019 Yongfu Scooter (A55853)
2019 Yongfu...
2018 MACK CHU613 DAYCAB (INOPERABLE) (A53843)
2018 MACK CHU613...
CFG Industrial MX15RX (A56469)
CFG Industrial...
