Fixing Up Drive Right
   / Fixing Up Drive Right #1
Farm Boss
Marysville Ohio
Ford 4000
I have got a 1200 foot drive that needs some gravel put on top. I am not sure what happened to the original stones but they seem to disappear over time. This property I bought a year or so ago and I want to fix it up right the first time. I contacted a quarry that will drop it along the drive. They priced out crushed limestone 310 at 12.50 per ton and #57 limestone at 13.50 a ton. I am thinking the #57 is the better product as it looks like it is bigger and less dust. Any downside to #57 besides the price. Anything else I need to consider? I am in central Ohio. Thanks
   / Fixing Up Drive Right #2
Gravel migrates...that said, the best way to prevent migration is with fines...the problem with #57's is there is no fines...recommendation is "crusher run"
That makes sense, I never heard about Crusher Run before. From what I see the 310 limestone is finer and probably more like this crusher run. I thought a gravel drive was simple but the more I read about it the more complicated it gets. Lots of choices. Thank you
   / Fixing Up Drive Right #4
An advantage to the #57 is the volume/weight ratio. You'll get more area covered per ton since the fines aren't there. You might investigate a grade called ABC-M. Around here, it's crusher run with a larger max stone size.
   / Fixing Up Drive Right #5
Up here its known as 3/4", 1", or 1 1/2" crushed. Basically refers to the size of crusher screen.
   / Fixing Up Drive Right #6
In our area "crusher run" is called "chips and dust". Same thing.
   / Fixing Up Drive Right #7
Might go with larger on 1st layer then crusher run, or fines material, as a top layer.
   / Fixing Up Drive Right #8
Any general guide-lines on tonnage/coverage?
   / Fixing Up Drive Right #9
DGA (Dense grade base) delivered dry works great. Same grade used under asphalt paving. Spread with truck, pack down by driving over with vehicle, sets up like concrete. Do you have a filter fabric underneath?
TEST YOUR BID BUTTON! (A52705)
TEST YOUR BID...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
Caterpillar 315C L Hydraulic Excavator (A53421)
Caterpillar 315C L...
1985 Miller Wildcat 350-D Welder (A55851)
1985 Miller...
TMA (A49461)
TMA (A49461)
2018 Caterpillar D5K2 LGP Crawler Tractor Dozer (A55787)
2018 Caterpillar...
