Ricn
Platinum Member
- Joined
- Sep 18, 2015
- Messages
- 519
- Location
- WA
- Tractor
- Kubota U-35, kx-040, Ford 8n, JD-280, JD380, JD1020, JD40C, Satoh Bull, Kubota L2501,
Good Morning to all.
my Post concerns a Woodmaxx 60 inch flail mower bought new in 2017. So here goes my question.
Have the Woodmaxx 60 inch flail mower and to date has worked great, no issues so far I know of. So, my Son was here yesterday and in his opinion, my mower is quite noisy. He is basing this from his US Brand flail on his Kubota Trac Hoe telling me, "it makes much less noise than my Woodmaxx mower".
Not hearing flails before, I thought the noise from mine was normal but now I wonder if it has issues? Since new, maybe two years now, and having very, very low hours, (I keep records) and having kept it greased in recommended intervals, I'd appreciate opinions on noise levels to be expected on three point flail mowers, if that is at all possible. Also, I notice after mowing that the black drive side housing covering the belts is warm, not hot to the touch mind you, but definitely warm, is that normal?
When I ordered my unit, the sales guy told me they had just upgraded their bearings to much better ones, and my unit when shipped, would have these newer bearings.
Judging mower noise is not easy unless hearing several units and brands for comparison: around here though I know of none to compare to, so any opinions from the experts here on TBN would be great. I will say, this mower runs up to speed quickly and easily and when the tractor is at idle speed, and engaging the mower, it spins with ease. In mowing 8-12 inch high grass at pto speeds there is no bogging down of the mower or tractor telling me resistance may be low? My tractor is 25 hp diesel not working hard at all running this mower. I plan to remove the black housing, check the belts and tensioner both but as it has no slippage I can see when mowing then perhaps I have bearing issues?
Thanks for any ideas you may have concerning noise.
Ricn
Ricn
