flat floor VS hump floor
   / flat floor VS hump floor #11
Yep, with a flat floor your feet are in line with the top of the hump.
I like the hump myself. :D
   / flat floor VS hump floor #12
Most likely the hump is left from the gear transmission days. Larger tranny, with shift tower. And, gear transmissions are still available, so some tractors still have the floorboard hump.
   / flat floor VS hump floor #13
All depends on the tractor I guess, both our HST and geared units have flat decks and I sure like them that way as I was always catching something on our Massey Ferguson 375 and I swear the older I got the taller that hump was.
   / flat floor VS hump floor #14
Personally I think I depends on the tractor usage. For instance, ag tractors, larger HP units, are designed for tillage, and having the operator higher in the air gives a greater field of view to be able to see all that is happening with the implements. This also allows the operator to be able to run a straight course, which is a source of pride to have straight arrow row crop rows amongst most farmers I know.
On the other hand, orchard tractors for instance, the operator doesn't want to be sitting up high, getting smacked with limbs and fruit. He wants to be lower, probably straddling the hump.
Dropping down into the smaller tractors, I think it becomes more of a design feature, with them (the designers) asking themselves questions like "If we put an open station on this small tractor will the operator look like an adult sitting on a pedal tractor?"
And I am not arguing the other points that were brought up, as I think they all bear some factor into the over design of the tractor. But ergonomics and operator comfort are all part of the reason that most of us bought the tractors we have.
Personally, I shied away from the hump tractors- wanting more of ag tractor - more foot space - higher vantage point feel. I felt more comfortable, but I am a big guy too.
My nickels worth :)
   / flat floor VS hump floor #15
We are replacing our 6210 JD, about 10 years old, with its updated version. Due to the height of 2 sheds we need the low clearance version which has a straddle rather than flat floor. It is an extra cost option, about $400 list. Much prefer the flat floor. JD says this option is really intended for orchards, another place where lower height is very important.
2014 Ford Escape (A50323)
2014 Ford Escape...
2017 Freightliner MT55 Box Truck (A55788)
2017 Freightliner...
Mini Excavator Pallet Forks (A53316)
Mini Excavator...
2017 TROXEL 130 BBL STEEL VACUUM TRAILER (A53843)
2017 TROXEL 130...
2006 Kenworth T300 Almac 2,700 Gallon Fuel Transport Tanker Truck (A55788)
2006 Kenworth T300...
Toro GreensMaster 1600 Walk-Behind Reel Mower (A55787)
Toro GreensMaster...
