Re: \"Flat monitor\" recommendations?
If you do any gaming, or otherwise use high speed graphics, you need to be careful. Most flat panel displays can't keep up with quality analog displays in this department. They don't respond fast enough. At least they didn't a year ago, when I last researched monitors. I ended up buying a Samsung 172x, which does have a fast response time. Of course, a year is a lifetime in the PC marketing game.
There are a whole slew of other specifications that may or may not be important, depending on how you use your monitor, including brightness, contrast ratio, horizontal and vertical viewing angles, and so on.
I would recommend you dig through the technical reviews on web sites such as pcmag.com and tomshardwareguide.com to get an idea of what is up to date today. The old no such thing as a free lunch maxim applies, and the cheaper the monitor, the more likely it is to be deficient in some aspect. You may find a $200 monitor in Walmart, but you probably won't find WallyWorld giving you enough specs to really tell you how well it will stack up against the competition.
One thing to watch out for is the manufacturer's dead pixel warranty. It is not unusual for a monitor to have one or more pixels that either are locked on or locked off. Locked on is much more of a nuisance than locked off. I have seen warranties that say you have to accept as many as seven dead pixels before the monitor will be considered defective.
This a good reason to buy locally instead of online, when it comes to monitors. If you get it home and find a dead pixel or two, you can always take it back to the store.
