Flat spots, who knew??
   / Flat spots, who knew?? #11
If they are Nylon cord, that's why polyester became popular....Nylon flat spots, poly doesn't for reasonable length sitting sessions. In the early days they used cotton fabric for cord which rotted and was a safety hazard.....hence Nylon became popular.
   / Flat spots, who knew?? #12
I've never had a flat spot problem. I've got Firestones on my Kubota M6040. The tractor with grapple, rear blade and Rimguard in the rear tires - weighs 10,100# Many times during any 12 month period - it will sit for two months without moving.
However - it sits on soft dirt in a single stall carport. I can see flat spotting if your tractor sits on concrete or asphalt or such.
   / Flat spots, who knew?? #13
The old nylon belted tires used to get flat spots regardless of temperature.
   / Flat spots, who knew?? #14
Yep. Just run your tractor down the interstate at sixty for a couple of miles, they'll be fine. That's what we did with cars.
   / Flat spots, who knew?? #15
My Kubota B26 got flat spots so bad that it loped along the road. I thought I had loose lug bolts or something. It has only happened one time in the summer. It may happen again as it has been setting for 3 months and likely will set for a couple more till spring gets here.
   / Flat spots, who knew?? #16
I store several cars seasonally.
I hate the hassle of jacking them up to avoid flat spots.
Instead; I air the tires up to 50 psi.
If there are any flat spots, they are very small.
I put a note in the car, to remind me that before driving I must reduce tire pressure.
   / Flat spots, who knew?? #17
When I was a younger man, Firestone came out with Firestone 500 tires, the had a gold stripe along with the white wall. They where the "cats meow" of the day. The only thing wrong with them was that they where made with nylon and as stated by many here, they would develop flat spots and for a few miles till they heated up, they car would thump thump down the road, but boy they looked sharp. Bob
   / Flat spots, who knew?? #18
So did Nylon cord without the belt; before belted bias became popular. The flat spotting is why the industry looked for a replacement and settled on polyester which was made to be strong, did not stretch (like Nylon) nor rot (like Cotton).
2003 Hyundai Elantra Sedan (A55853)
2003 Hyundai...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A56129)
2019 INTERNATIONAL...
2017 Ford F550 Altec Bucket Truck (A52377)
2017 Ford F550...
2010 Hyundai Elantra Touring Sedan (A55853)
2010 Hyundai...
KSI Conveyor (A55301)
UNUSED Polyester Arborist Outdoor Rope (A53117)
UNUSED Polyester...
