RalphVa
Super Member
- Joined
- Dec 19, 2003
- Messages
- 7,885
- Location
- Charlottesville, VA, USA
- Tractor
- JD 2025R, previously Gravely 5650 & JD 4010 & JD 1025R
sixdogs; I may have led you astray by saying my '07 oil change interval was 7500 miles; by the manual, the change interval on that vehicle was 5000 but I chose to go to 7500 because of the use of synthetic oil. The manual stipulation of 5000 miles was with the use of conventional petroleum oil, as of that period Toyota did not recommend the use of synthetics, for some strange reason. The recommended interval on my '16 is 10,000 miles, but the engine is identical to the '07 Tundra; a decision you'll have to make for yourself
I think Patches has it right.
I actually switched to Mobil 1 0w20 in my Tacoma. Gets better fuel mileage, as it reduces the pumping losses. Change it about every 3 years since I only put 2 to 3k miles/yr on it, maybe less now that I have a Miata and wife her Mazda3.
Toyotas are good appliances. Work and don't require much other than normal maintenance. Had this Tacoma into its 12th year now. Only had to take it in for a couple factory recalls of seat belt and undercoating. Nothing else (the dealer I bought it from had done the brakes). Passes inspection every year. Decided to keep it around because it goes when I need a pickup. Thought about putting a hitch on the Miata to be able to pull a light trailer for my yearly leaf hauling and one of those racks that go into the hitch receiver to haul fuel. Wife convinced me to keep the Toyota Turd.
Ralph
