Flexible top link for bush hog?
   / Flexible top link for bush hog? #41
</font><font color="blue" class="small">( Now I know the rest of the world can't be all wrong, so what am I missing here? If the tale wheel will freely follow the ground then whats the point? /forums/images/graemlins/confused.gif )</font>
One thing I can think of: Without a top link to limit tail wheel drop, if you run over a sharp hill (like a levee) the brush hog's front end could really gouge in deep.
Other than that odd situation, as far as I know, the top link's only purpose is to lift the brush hog for traveling.
Unrelated to actual mowing, the top link is real handy for lifting the bush hog up nice and high for blade sharpening. So I'm keeping mine.
I didn't explain this right, I did not mean that I left the top link out. I still have the top link connected, just that its connected directly to the bush hog with a solid pin and does not use a flexible link. My point was that even with this 'solid no flex' 3 point hookup the rear wheel can still move freely up and down and pivots about the lower links.
Sorry about the confusion. /forums/images/graemlins/laugh.gif
   / Flexible top link for bush hog? #43
"What's the point?" I think you missed it. /forums/images/graemlins/wink.gif But no offense, you will some day have an aahhhh soooo 'awakening', as I did once. /forums/images/graemlins/wink.gif
   / Flexible top link for bush hog? #44
I think you are missing some of the geometry. The hog cannot pivot onthe bottom links witht he rigid toplink in place. up pressure on the tail wheel should 'lift' the mower as the 3 links will allrise together. If the mower did actually pivot on the lower links.. the toplink would be bending...
Soundguy
   / Flexible top link for bush hog? #45
I've been following this thread since day one, with some interest. Now that everyone has had their say, I'll weigh in.
I have a Woods BB840 mower. It has built-in "flex" that allows the top-link "mast" on the mower to move, allowing the mower great flexability. With the mower in "mowing position", I set the top link to allow as much up-and-down movement as possible. The rear wheel could DROP as much as a couple feet with no trouble. It can also RAISE a couple feet. (mind you, this is a 7' mower. It's LONG. That exagerates the up/down distance over, say, a 5' mower)
So as to be able to RAISE the mower SAFELY over obsticles without dragging the rear of the mower over them, I employ the use of a hydraulic top link. When I need to raise the rear of the mower up high, I merely shorten that top link long enough to raise the mower, then return it to the desired setting before continuing.
By allowing so much "flex" I eliminate stress and strain on the 3-point linkages when crossing irregular terrain. By using the hydraulic top link, I eliminate the problems associated with "too much top link slack".
Works great, mows safley, and doesn't destroy equipment.
<font color="blue"> The hog cannot pivot onthe bottom links witht he rigid toplink in place. up pressure on the tail wheel should 'lift' the mower as the 3 links will allrise together. </font>
Yeah you're right, again I did not describe it right. Even so, the back wheel does move relatively easy up or down.
All this aside, its still probably a good idea to have a little flex so as to ease the effort. I'm going to make up a flex link when I get a chance, even though I've never had any problems in all the years I've mowed without it, I think my little tractor will be happier.
Hey, and thanks to all for the discussions, I learned a lot. /forums/images/graemlins/laugh.gif /forums/images/graemlins/grin.gif
   / Flexible top link for bush hog? #47
</font><font color="blue" class="small">( I posted this original question a while back, as to why the need for a flex top link. Today I had to mow the last pasture on our land so I hooked up my bush hog sans any flex top link, and before I started I decided to try a little experiment. I parked the tractor on level ground and lowered the hog. I next took a wood lever and proceeded to raise the back tire of the hog. Well, the deck just pivioted on the 3 pt lower links any easily moved up and down. So to my dumb eye it looked like the tale wheel would do the same on uneven ground, that is move up and down without any flex top link.
I don't understand, but I would like to. What you did - use a solid top link so your mower is solidly connected to the tractor 3pt on all 3 points; _and_ be able to lift up the rear of the mower with a bar more than an inch or 2:
Should not be possible. Can't be done.
The only possiblitiy I can think of is that your mower is designed with a flex link from the upper 3pt arm socket to the rear of the mower???? In that, the mower itself will swing up & down? This could have been designed in, or some stablizer arms could have been removed by you or the previous owner?
_Most_ mowers are designed with a ridgid, hard, unmovable framework from the mower deck to the upper 3pt socket. If you use a rigid upper 3pt arm with this, then the mower cannot pivot up & down as you describe. Law of physics and all. (With the fre-floating 3pt hydraulics, you can raise the mower up of course, but that is a parrallel raising, not a true, helpful pivot action that we are looking for?)
Now I'm not doubting you, and not trying to open a can of worms. /forums/images/graemlins/smile.gif
I'm just trying to understand? What you describe as working - should not.
--->Paul
   / Flexible top link for bush hog? #48
Very interesting - Here is my 2 cents worth:
To solve the problem of a "flexable" top link when mowing I installed a hydraulic top link, the valve has a FLOAT position. When mowing I place the valve in float and the cylinder extends / retracts as needed when mowing up & down dips. Works great. No chains, no removing / installing / adjusting various top links. Just move the hydraulic lever into the float detent and all is good.
<font color="blue"> GuglioLS.......I installed a hydraulic top link, the valve has a FLOAT position..... </font>
Now thats classy! Yup, a very good way to go. Trouble is though I don't have a hyd top cylinder.
<font color="blue"> --->Paul ... you can raise the mower up of course, but that is a parrallel raising, not a true, helpful pivot action that we are looking for?</font>
True again, it is more of a verticle lift rather than a swinging pivot, but it did seem to move pretty easily. I used a 5' 2x4 over a block of wood and it lifted up as far as I had lever space. As I said, it seems that would be enough.
OK, I think I've worked this thread to death, don't know if anything was truely resolved. Fun disscussion though. /forums/images/graemlins/grin.gif
   / Flexible top link for bush hog? #50
</font><font color="blue" class="small">( <font color="blue"> The hog cannot pivot onthe bottom links witht he rigid toplink in place. up pressure on the tail wheel should 'lift' the mower as the 3 links will allrise together. </font>
Hey, and thanks to all for the discussions, I learned a lot. /forums/images/graemlins/laugh.gif /forums/images/graemlins/grin.gif )</font>
Unless there is something else no the rear wheel won;t move up and down. Maybe the complete 3pt is moving up and down with draft control or something. Otherwise it'll pick up the back of te tractor. These guys are trying to explain it as simple (and nicely) as possible.
2007 International 4300 Dump Truck (A51692)
2007 International...
2022 Club Car Tempo Cart (A55853)
2022 Club Car...
5004 (A55851)
5004 (A55851)
2016 Ford Expedition SUV (A55853)
2016 Ford...
1839 (A51248)
1839 (A51248)
2006 FORD F-450 XLT SUPER DUTY SERVICE TRUCK (A51247)
2006 FORD F-450...
