Float charger on a jumper back battery?
   / Float charger on a jumper back battery? #11
There's no big secret in caring and charging LA batteries. They are typ charge with a constant voltage source. As long as the voltage is well regulated and is of proper voltage, you shouldn't have any problems. If you have problems with battery running dry, the voltage it too high. With proper voltage, water usage will be minimal. Proper voltage should range between (this is for nom 12 V battery) is 13.25 and 13.8. The longer you intend to leave the charger connected, the lower the voltage should be. Typ you will find that multi-stage chargers are set for ~13.25V for their final stage.
LA batteries don't like to be left in a partial/full discharge state. Hard to recover a battery that has been left in a discharged state for any period of time.
I make sure of the charge voltage and for batteries that sit for months during the winter, I make sure they were fully charged at the end of the season. Batteries typ last me 5-6 yrs.
   / Float charger on a jumper back battery? #12
Do yourself a favor and get a Battery Tender. I have two of the waterproof variety, a 4-bank version, and a single. Keeps all the camper, tractor, car and motorcycle batteries healthy year round.
PALLET OF CHAINS AND BINDERS (A53843)
PALLET OF CHAINS...
Mohawk 12,000lb Two-Post Electric Auto Lift (A51691)
Mohawk 12,000lb...
2015 Ford F-150 Ext. Cab Pickup Truck (A53422)
2015 Ford F-150...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
CUSHMAN HAULER 1200 GAS GOLF CART (A51406)
CUSHMAN HAULER...
2018 RAM 2500 SERVICE TRUCK (INOPERABLE) (A53843)
2018 RAM 2500...
