Floor/crawl space Insulation ?
   / Floor/crawl space Insulation ? #1
logan97
Blue Ridge Mnts, Va
Kubota B7800 4/wd
code here is R-13 in a crawl space should I increase the R value ? I have until this Tuesday to make a decision. $300 upgrade to R-15, upwards from there as it increases. Batts the spray would be 1/2 the cost of the entire job.
   / Floor/crawl space Insulation ? #2
I can't imagine you'd notice any difference between R-13 & R-15.
   / Floor/crawl space Insulation ? #4
Always felt the more the better. Spray in type would be better if you can stand the cost and will not have to worry about the batts falling down later on. Just my opinion mind you
   / Floor/crawl space Insulation ? #5
In a crawl space I would go for spray foam.
The rodents sure like wool batts as nesting sites.
   / Floor/crawl space Insulation ? #6
Hey, neighbor... go for the most you can afford. Do it once, do it right...
   / Floor/crawl space Insulation ? #8
I had my floor insulation pulled out last Nov. It was just a moisture magnet and rat/mice haven. Moisture levels in the crawl space dropped to an excellent 15-16% and we noticed no colder floors this cold winter then before (well, cold for us).
Good luck!.
   / Floor/crawl space Insulation ? #9
Good luck!.
Now hold on ftg, ye ain't got nary insulation now in ye crawl space? Hmmmm, I need to do something. No matter wha' ye do, make sure the ground is covered real good with about 6 mil polymollymajolly, wha' ever it's called. Y'all know.
   / Floor/crawl space Insulation ? #10
Nope, no insulation for the last year - this is my now previously owned house, it got sold a couple weeks ago.
I have several layers of 6 and 10 mil plastic installed. It's a very dry crawl space, which is what I wanted.
2015 Honda Accord Sedan (A53424)
2015 Honda Accord...
UNUSED LANDHONOR MPF-11-2000G PALLET FORKS FRAME (A54757)
UNUSED LANDHONOR...
Ingersoll Rand Air Compressor (A52377)
Ingersoll Rand Air...
2010 Lincoln MKS (A50324)
2010 Lincoln MKS...
2012 Honda Accord Sedan (A53424)
2012 Honda Accord...
2019 FREIGHTLINER M2 106 REFRIGERATED TRUCK (A52706)
2019 FREIGHTLINER...
