Floor Treatment for covered Screen Porch
   / Floor Treatment for covered Screen Porch #1
HawkinsHollow
SE TN
Branson 3015R
Need to figure out what I want to put on the floor of my newly screen covered porch. It stays mostly dry in all the but the craziest of rain storms but I am still going to be cautious what I put down. I would love to put composite tongue and groove, but have you seen the price for that stuff? Not happening! The short list right now is wood look tile (lots of work and not cheap), slate tiles (even more expensive and laborious) and these wooden squares. The subfloor is avantech.
I really like the squares but the wife is concerned about dirt getting down in the cracks and being hard to remove. The squares are the cheapest and easiest option by far. I think a shop vac once a month will take care of the dirt that might get down there. What says ye?
   / Floor Treatment for covered Screen Porch #2
I've done a few vinyl floors for clients with screened in porches. It's the easiest to do yourself and probably the lowest price flooring out there.
I personally like tile and I've been stocking up on what seems to be the most expensive tile ever sold at Lowes. It's a really nice 4x8 tile that will give lots of traction for my dogs and grandson when he's playing in the pool. I buy a case just about every week and hope to have enough by this time next year.
   / Floor Treatment for covered Screen Porch #3
View attachment 3421558View attachment 3421559
I confess that I'm with your wife on that one. I wouldn't sign up for something that is going to be high maintenance, and I think with those cracks outside are an invitation to dirt.
I've had both vinyl and ceramic/stone tile. They both work well, but watch out for the slip hazard if vinyl or glazed tile gets wet.
@EddieWalker what is the tile that you like?
All the best,
Peter
I am not sure I can stomach putting vinyl on my porch. It always seems so cheap. I am not sure I have ever seen a vinyl floor that I was like "WOW, that looks amazing".
  • Good Post
Reactions: JJT
All the best,
Peter
I know, I have to admit in my heart I feel that same way. But I love the way they look and wish I didn't have reservations about them.
   / Floor Treatment for covered Screen Porch #6
I agree- they look nice. Larger ones (2x2' or larger) might work as something that you could pull up and put down after cleaning, but in my experience they tend not to be dimensionally stable, especially outdoors.
You could do solid parquet, with a flood epoxy or multilayer varnish surface, but that's going to need annual work to keep the sun/rain exposed areas stable.
Did I mention that I am a fan of low maintenance?
All the best,
Peter
   / Floor Treatment for covered Screen Porch #7
Vinyl snap together planks are being used in fairly high end new homes. most of the time, the wood looking planks are so good that even when you touch it with your hand, it's hard to believe it's vinyl.
Here is the link to the tile I'm buying at Lowes. The pictures are a lot brighter and lighter color than what they are in person. I'm a huge fan of earth tones and natural colors. I think that I need about 60 cartons to do my porch, and I'm at 35 right now. I'll buy another this week if it's in stock. Normally there is 4 or five boxes of it on the shelf. Never enough to do a room, so I'm guessing that everyone is buying a box at a time until they have enough. It's probably the wackiest thing I've done for home remodeling, but with so many other projects that have to be done, this is my way of working towards that project without causing a lot of pain by buying it all at once.
   / Floor Treatment for covered Screen Porch #8
Your wife may be similar to mine: low tolerance for dirty looking floors. I would avoid flooring that shows dirt and has recesses for dirt to collect. You'll never hear the end of it.
   / Floor Treatment for covered Screen Porch #9
Our closest neighbors have two adjoining screened in porches, both about same size. The one has linoleum and screened in, a couple small throw rugs & cat door. Two doors one each end. The other has expensive windows with screens, a block floor like that and sliding doors into the house. It has a large rug & nice furnature. So through the house that porch stays clean. Going from outside the other way there's a sidewalk and linoleum easy to clean...into the nicer side that floor stays clean.
Our porch a couple years ago I got tired of painting concrete so made a wood (2x8s) frame covered with T&G 3/4 plywood, all PT, then covered with roll roofing then Trex. I had front door house side 1" higher than steps side so never standing water. I occasionally blow it off if needed.
Yeah, ok!! You're probably right.
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
2015 Ford Escape SUV (A53424)
2015 Ford Escape...
2012 Ford Fusion Sedan (A55853)
2012 Ford Fusion...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A55314)
2023 Unverferth...
2018 Ford Explorer AWD SUV (A53424)
2018 Ford Explorer...
Toro Mower (A50324)
Toro Mower (A50324)
