Flooring Ideas?
/ Flooring Ideas? #11
First idea is to use 3/4 inch plywood and "box" in there the joints come on the butting edges between the joist
maybe I am reading this wrong...but all the but ends of the plywood or OSB (T&G w/ glue is highly recommended) should break on top of a joist?
sorry if missed something and this is off the wall...
/ Flooring Ideas? #12
I'm a little confused here. Are we talking glue down vinyl flooring or ceramic tile? If it is ceramic tile, I thought the subflooring needed to be something like 1 1/4 inch thick to stop any deflection that would crack the tile.
/ Flooring Ideas? #14
2x6 floor joists on 16" center will deflect/bounce with 3/4" t&g or OSB or plywood. recommend that you mate another 2x6 to each existing joist. generous with the nails,liquid nails would help too.
/ Flooring Ideas? #15
Unless the span is very short, I agree 2x6 will deflect.
If you can take all the load off the floor by removing everything in the room, and if you have access to the bottom, consider adding a layer of 3/4 OSB or plywood on the bottom of the joists. Screwed and glued with liquid nails. Let this set up & dry for a couple of days before walking on the floor.
As far as the flooring goes, for vinyl, flexible stuff, they used 3/8 pressboard on top of our OSB subfloor in the kitchen and it has been very good. I would use this before I used luan.
Our floors are 3/4 OSB on 12" centers and have no bounce at all. Now we kept the BCI span to about half of the claimed amount and that helped a lot.
INTERNATIONAL EAGLE ROAD TRACTOR (A52707)
INTERNATIONAL...
Komatsu HM400 (A60462)
INTERNATIONAL 454 TRACTOR (A62130)
INTERNATIONAL 454...
Harlo HP6500 (A60462)
DRAGON 500 BBL FRAC TANK (A58214)
DRAGON 500 BBL...
DEUTZ MARATHON...
