Fluid and power steer
   / Fluid and power steer #1
mbull
2005 L2800.
My power steering seems week or binding. Tractor has 90 hrs., no front end loader.
Did filterr change, no help. Fluid looked OK.
Should I change fluid also?
Where do you drain it?
What is refill capacity?
Thanks in advance for any help.
Can anybody give suggestions?
   / Fluid and power steer #3
90 hours in 4 years??
Most folks change hydraulic fluid after 50 hours. At 4 years many owners might change it out of boredom.
Assuming the hydraulics work, about half of steering problems are due to leaking o-rings in the steering ram. Yours have been sitting unused so much, could see that happening.
Worst thing you can do to a tractor is not use it....
Would these leaking o-rings be visible? There are zero signs of leaks anywhere on this tractor.
   / Fluid and power steer #5
No, they are internal to the steering ram, between the opposing hydraulic loops.
However, a leak there won't make the steering wheel bind. The steering wheel still turns, just the steering doesn't follow.
Problem solved. Filters and fluids were not the issue. I remembered reading a post awhile back about return line (from filter to hydraulic pump) that was prone to cracks. Took rubber line off, found crack, replaced, all is like new.
   / Fluid and power steer #7
Glad to hear that you solved your problem but yes, 90 hours in 4 years :confused:? I would proceed with the 50 hour service regardless if you solved the steering problem.
Welcome to TBN!!!
iDrive TDS-2010H...
2007 JLG E400 AJP TELESCOPIC/SCISSORING MANLIFT (A52707)
2007 JLG E400 AJP...
2004 AGCO Gleaner 3000 Corn Header (A61307)
2004 AGCO Gleaner...
2015 CATERPILLAR 953D CRAWLER LOADER (A60429)
2015 CATERPILLAR...
13042tx (A55973)
13042tx (A55973)
2012 HYUNDAI  HL740-9 WHEEL LOADER (A58214)
2012 HYUNDAI...
