Tires fluid filled tires and Harley Power Rake?
   / fluid filled tires and Harley Power Rake? #11
He was my solution to the hight cost of factory wheel weights. Home made wheel weights
They use bar bell weights. I have 200 lbs on each side.
   / fluid filled tires and Harley Power Rake? #12
There's another reason for filling the tires. It also lowers your center of gravity quite a bit, the tractor will feel alot more stable on slopes and rough ground not to mention the traction increase. Talk to a couple tire shops in your area to see what they charge to fill them and what they use most. I used AF, this also helps on the corrosion side but I don't know if WWF helps any with that.
Larstan, I will talk to my local tire shop. What is (AF)? I had not thought of the corrosian aspesct of wwf. Water, even with soap will corrode.
   / fluid filled tires and Harley Power Rake? #14
My dealer uses methanol, no corrosion at all and no freezing.
   / fluid filled tires and Harley Power Rake? #15
gregp,
</font><font color="blue" class="small">( What is (AF)? )</font>
AntiFreeze, I have been told that calcium causes problems down the road. I have no clue as to the wwf's long term issues so AF seemed like the logical choice.
</font><font color="blue" class="small">( I had not thought of the corrosian aspesct of wwf. )</font>
If there are any chips or nicks on your rims then you will have a corrosion problem with adding water, I don't know if wwf has any anti corrosive properties, but I do know that AntiFreeze does. It's just like a compressor, it will rot from the inside out and you won't know till you go to change a tire or it fails......
I am sure one of your local tire shops fills tractor tires, I think the going rate up here was about a buck a gallon. I got them to do it for .60 a gallon and I thought that was still high plus the cost of the AF. Took 44 gallons each in the rear and 4 each up front, cost me 60 bucks for the fill plus 2 cases of AF. But the handling was night and day, it might be a little nimbler without but I have alot of rolling pasture with gully's and some steep slopes. Keep the seat side up /forums/images/graemlins/grin.gif
2016 Husqvarna YTA22V46 46in Riding Mower (A56859)
2016 Husqvarna...
2019 CAT TL1055D (A58216)
2019 CAT TL1055D...
2177 (A58376)
2177 (A58376)
JOHN DEERE 333G SKID STEER (A52709)
JOHN DEERE 333G...
Miller Bobcat 250D Diesel Welder (A57453)
Miller Bobcat 250D...
Year: 2017 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 101,691 Plate: Body Type... (A55853)
Year: 2017 Make...
