Wayne County Hose
Veteran Member
- Joined
- Aug 24, 2007
- Messages
- 2,325
- Location
- Wayne County Pa.
- Tractor
- Massey Ferguson model 85, Allis-Chalmers WD-45
geobar said:I run Dexron in my 2004 Jinma 284, and find that it performs better then it did new with no drawbacks so far. Be careful though because atf and hydraulic fluid do not mix. You will need a complete flush to make it permanent on the atf. My 2004 hyd system was filled with motor oil from the factory and atf will mix with that so I did not have a flush situation. I flushed and switched my snow plow to atf because hydraulic fluid absorbs moisture from the air and I kept getting ice in the system at the start of every winter. IMO atf flows, lubricates, inhibits rust better and keeps the system cleaner.
???????? I've mixed them a thousand times and never had a problem.
