Fluids and oils fx255
   / Fluids and oils fx255 #11
Hi all
New guy looking for some info. I have a fx255 that I am more then happy with. I have had it for about a year. I would like to change out the fluids and oils. What oils are required for the engine, PS, front axle and hydraulic system/ trans? Is a Yanmar brand filter required for the hydraulic system or is there an aftermarket brand available? I already have the engine oil and air filters. Is the rather large metal reservoir on the left front of the engine bay next to the battery for the PS fluid? It has a yellow cap and no dipstick. What is the level supposed to be?
Thanks Brad
Brad,
That would be your power steering reservoir, there is a bolt on the front of the tank, remove it, pour the fluid in on top(yellow cap), when it pours out the bolt hole, its full !
Thanks Ernie
That was just the info I was looking for. I was wondering how you check the fluid. Is there a NAPA filter for the hydraulic system?
Thanks Again All
Brad
   / Fluids and oils fx255 #13
Heres what I use in my FX255-D
eng.= chevron delo 400 15-40 or synthetic oil shell rotella
eng filter = napa #1064
Trans.= ATF automatic trans fluid= mercon dextron
Power steering tank = ATF
front axle = 90 weight gear oil
radiator = 50-50 mix
fuel= red farm diesel with power service added.
Waist size 33;)
Same here ; No object in paying 30 to 50 cents a gallon highway tax on the fuel when you don't have to.
2023 Top Air ATV 200 Gallon Pull Type Sprayer with 30ft Booms (A56438)
2023 Top Air ATV...
2018 CATERPILLAR 336F L (A58214)
2018 CATERPILLAR...
2016 Chevy Silverado Z71 4wd 5.3L V8 (A56438)
2016 Chevy...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
Zero Turn Mower (A59231)
Zero Turn Mower...
Schulte SBW800 Rock Windrower (A56438)
Schulte SBW800...
