Gale Hawkins
Super Member
- Joined
- Sep 20, 2009
- Messages
- 8,268
- Location
- Murray, KY
- Tractor
- 1948 Allis Chambers Model B 1976 265 MF / 1983 JD 310B Backhoe / 1966 Ford 3000 Diesel / 1980 3600 Diesel
Diesel is a good option in most cases but I find the old 303 UTF for around $20 for 5 gallons on sale which cost wise is not that much more. Under no load I will actually run the gear box a bit then drain. If some gets trapped and does not drain completely it is still lube oil and not diesel. A lot of old gear boxes do not have a low point drain on our stuff so I have to suck it have to suck it back out or turn it upside down.
How ever often I will do the diesel flush before the 303 flush. If the fill plug is large enough I like to use the diesel in a hand pump pressure sprayer on solid steam for flushing action. I know shops just kind of drain and refill often.
