Flywheel Installation Problem John Deere 445
/ Flywheel Installation Problem John Deere 445 #1
445JohnDeere
John Deere 445
I recently put new rings and oil seals on a Kawasaki FD620D out of a 2000 John Deere 445. I pulled off the flywheel to do this. After the engine was reinstalled I could hear a random ticking sound coming from the flywheel area of the tractor. It sounded like the tip of a fan blade just touching something now and then. The sound remained after disconnecting the drive shaft and the fan. I pulled the engine back out and pulled the flywheel off. The flywheel popped off the tapered shaft while I was hand tightening the puller which is odd because when I originally pulled the flywheel off it required much turning by an impact gun on the puller. I am not surprised by this because at install the Flywheel nut seemed to become very difficult to turn before it came into contact with the flywheel. So I think the flywheel is not seated properly after the factory service manual torque has been reached. The only thing I can think to do is add a 2nd washer before putting the nut back on. Does anybody have any experience with this type of problem or can see what I did wrong? Thank you for your time.
/ Flywheel Installation Problem John Deere 445 #2
If the flywheel was located on the tapered shaft with a half-moon shaped key, my guess is that it shifted in the keyway. Normally that will be a parallel-sided key. A half-moon key has to be carefully installed so that the straight side of the half moon key stays parallel to the taper as the flywheel slides on.
To check this - or just for doing the job by best practice - you can slide the flywheel on without a key in the slot and measure how much threads stick out.
good luck,
rScotty
good luck,
rScotty
Thank you for the information. I did as you instructed and I added a couple of washers because I think there was something wrong with the threads closer to the taper. I put the engine back in and it is still making the same noise. However, now it comes and goes. I really don't know what it is but I am going to assume it is nothing too serious. I am just going to run it and see what happens.
SAND BLASTER AND GEAR (A60736)
SAND BLASTER AND...
2024 Linx UT357712T 7'X12' Single Axle Trailer (A60463)
2024 Linx...
1995 John Deere 7400 (A60462)
1995 John Deere...
Iranch IRET13 (A60463)
2019 FREIGHTLINER M2 4X2 26FT CDL REQUIRED BOX TRUCK (A59906)
2019 FREIGHTLINER...
FORD 8630 POWERSHIFT TRACTOR (A62130)
FORD 8630...
