fog in dash panel
   / fog in dash panel #1
grainger12002
Platinum Member
Pomfret,Connecticut
yanmar 336d w ldr,Cub,many attachments
Has anyone had this fixed to the point that it no longer fogs? I read in the JD column that JD has a treatment thta tempers the dash plastic so it no longer fogs-New Holland replaced ours and it continues to fog-up.wondering if you share the same problem-Lloyd
   / fog in dash panel #2
My dealer replaced my instrument panel in September, but I noticed yesterday that it was starting to fog up after several hours working in the cold. It shouldn't be this difficult ...
Brad in NH
   / fog in dash panel #3
I've learned to live with mine...heating the lens would be the only dependable solution. I'd think sealing the unit may be a bit bothersome given the nature of the service and the wide range of environmental conditions it has to withstand.
Snowmobile helmets now have heated face shields to keep the fog off and fire trucks use heated gauges to keep them fog and frost free.
It seems a couple of bands of heater wire stratigically placed to look like it belongs would be NH's best solution. To go all out a sensor can be added to cycle the strip heater.
Until they do some re-engineering, I'll just deal with it.
   / fog in dash panel #4
TC25D dash fogged up the 1st winter (last year) that I owned it. Seems to be a little worse this year. My windsurfing boards all have vent plugs for pressure compensation. Since I trashed a wave board this summer I've got a spare plug. Tempted to install it into dash if possible. Anyone out there try venting their dash to deal with this problem?
   / fog in dash panel #5
grainger12002,
I had mine replaced last March, so far no more problems
Nick
   / fog in dash panel #6
Heard over on the JD posts that JD cured the same problem with anti-fog treated plastic on the inside. Mayb NH should take some pointers.
2017 Nissan Murano SUV (A50324)
2017 Nissan Murano...
2014 MACK GU713 WATER TRUCK (A51243)
2014 MACK GU713...
2015 FORD F-150XL SINGLE CAB TRUCK (A51406)
2015 FORD F-150XL...
2015 Ford Expedition EL XLT SUV (A50324)
2015 Ford...
2008 FORD F-250XL SUPER DUTY EXT CAB TRUCK (A51243)
2008 FORD F-250XL...
CATERPILLAR 962M LOADER (A51242)
CATERPILLAR 962M...
