Follow up on Ice Storm Gen Thread - How much power does a house take
   / Follow up on Ice Storm Gen Thread - How much power does a house take #21
If you plan on running electric heat you better get a big generator. I have a 20,000 BTU electric heater in my garage. I don't know the exact amp draw, but it is on a 30 amp 220 breaker. My upstairs heat is electric, and it has a 6 gauge wire running to it. I never use it because it is so expensive to run. If I had it to do over I would put in a gas upstairs. My primary heat is wood, and my downstairs furnace is gas. Sometimes it gets a little chilly upstairs, and it would be nice to have a furnace that didn't cost a fortune to run. As it is we use no heat upstairs and rely on the heat rising principle.
roughly 5900 watts and about 25 amps
   / Follow up on Ice Storm Gen Thread - How much power does a house take #22
   / Follow up on Ice Storm Gen Thread - How much power does a house take #24
They heat with wood in wood stoves. Its so hot and dry by the stove you dry your clothes on a drying rack or line in the stove room and i bet that the clothes dry faster with a fan in the room then they do outside in Canada in the summer! Least they would in my stove room than in summer
Yes, my clothes dry faster in winter in front of the wood stove than in summer.
Stove top "burners" vary from 750W to 2250W. Ovens 2250W to 4800W. Each bank of heaters in a forced air electric furnace is usually 5000W or so and about 20amps.
So this is the slice of info I was looking for but didn't know to ask. Helps out a lot to know an individual burner needs (Hmmm Top Ramen on a cold night with no power).
   / Follow up on Ice Storm Gen Thread - How much power does a house take #26
Ill post up as its a follow up to my thread :)
we have natural (grid) gas here at the house.
My forced hot air gas furnace drew about 1200w on startup (i think its a 1/2hp blower motor) but its a high efficiency furnace meaning it has a small secondary exhaust blower also. and about 500w running.
If the electronics go out (like mine did) the burner will not fire. But you can turn the blower on "manually" through the thermostat or if the real SHTF the blower is several heavy thick wires that connect to the electronic board (if you have a new furnace) you pick "2" and run it. Mine has several leads because its a multi speed blower (again has to do with the high efficiency furnace)
My hot water heater is gas. Takes no electricity to make hot water. We had hot showers both days. (after we came in from running the chain saw for hrs outside)
We are on grid water, so no well pump to power.
When the furnace and fridge were unpluged i did try to run my 1800w toaster (i think the computers and some lights were on at the time for about 250w load) and my little genny tried but after it grunted for 5 or so sec and didnt "catch up" i decided id toast my toast on the stove.
my desktop computer, 2 monitors, the cable modem, wifi switch, and 2 CLF lights was ~250w load.
My fridge was 1250w startup 600w running.
I have a gas dryer, we didnt run it. We did no laundry when the power was out. I did not run the dishwasher (with its huge arse heating element) while the power was out. I could check both the washer and dryer this weekend with my Kill-a-watt and report back. (and then *I* would know also)
   / Follow up on Ice Storm Gen Thread - How much power does a house take #27
over the last 12 months, my house is averaging 72 KWH/day. That's the highest it's ever been, mostly due to a very cold winter last winter.
Over the life of my house (18 yrs), it averages 44 KWH/day. Before I installed geothermal, it averaged 40 KWH/day over 14 yrs, and I was heating with oil. Since installing geo, it averages 60 KWH/day for the last 4 yrs. I think the biggest increase is because of teenagers and doing laundry, not to mention long showers. I also added sq ft's to the house when I added the geo, as I now condition space above my garage that was previously non conditioned space.
I already have one of the most economical water heaters, but have not hooked up my desuperheater on the geo yet. I have also replaced my most frequently used lights with LED.
It's hard to make apples to apples comparisions, even in my own house due to the changes I've made. I really hate getting these letters from the power company about how I use so much more power than my "efficient" neighbors. It does not look at size of house, type of heating, or anything meaningful to compare, just usage. I hate even more the fact that I get billed every month on my elecric bill for that state mandated program. It was almost $10 last month alone. that's the program that gave me some "free" broken cfl light bulbs a few yrs ago.
As I type the dryer is started for the 3rd time this morning.......
   / Follow up on Ice Storm Gen Thread - How much power does a house take #28
you know these are like $40 brand new. even less at garage sales or CL
they take up no space on a closet shelf and the propane never goes bad.
   / Follow up on Ice Storm Gen Thread - How much power does a house take #29
Not to hijack this thread; but,
Would it be better for emergency purposes to have a PTO generator or a portable gas/diesel generator? I have been kicking this question around for some time.
   / Follow up on Ice Storm Gen Thread - How much power does a house take #30
My thinking was that I might need the tractor for other things at the same time. Plus it's easier to transport the portable generator if I need to.
But the diesel engine on my tractor should outlast a gas engine on the generator.
There are pros and cons.
HONDA EU2200EI INVERTER GENERATOR (A50854)
HONDA EU2200EI...
2008 GMC C7500 Altec LRV55 55ft Forestry Bucket Truck (A50323)
2008 GMC C7500...
2009 PETERBILT 340 (A50854)
2009 PETERBILT 340...
2016 CAT 980M WHEEL LOADER (A50854)
2016 CAT 980M...
2012 PETERBILT 337 (A50854)
2012 PETERBILT 337...
New JMR 78" Double Skidloader Grapple (A50774)
New JMR 78" Double...
