Follow up report / rubber tire chains.
   / Follow up report / rubber tire chains. #21
Trev, I bought a set from tirechain.com for just the front of my tractor. I have R4s and 4wd. They are 2 link chains...and very heavy , well made chains. Expensive though...around $200 with tensioners. I have a steep gravel driveway. I decided to go just front based on info from this forum. I am very happy with mine....they have had a workout lately. Even just this evening, I got out and worked on some of the ice we had. They work great, and sure add to my confidence level. I have a fel, so a lot of weight up front. With the chains up front, I believe you can steer better. At this point, don't see a need to buy back chains. Also, when I got my chains adjusted like I wanted, I used a bolt cutter and got rid of some of the excess chain so it wasn't slapping the front axle.
   / Follow up report / rubber tire chains. #22
I put 2 link chains on the front tires of my 4410 and they work great. I have a 15 degree concrete driveway that most of the time I could make it up. Now with the chains no problems. I bought mine at my John Deere dealer for less than tires chains wanted, plus no shipping, no handling charges and no sales tax.
Mike
   / Follow up report / rubber tire chains. #23
I would be real careful chaining all 4 tires - could run into warrenty issues, and put a lot of stress on the drive train. It shouldn't be neccesary. I'd check with the manufaturer anyhow be4.
Front or rear - if you don't _always_ run in 4wd, put them on the rear. Or if you are using rear-mounted equipment - blade, blower, etc.
If you have a light rear end & use front-mounted equipment, then chains on the front will be more effective, altho rear chains will still do a lot for you.
Just remember, the chains will make that axle pull more, and tractors seem to always have a stronger rear axle than a front drive system (with all the knuckles & pto & gears & transfers...) so whichever axle you put them on, you will cause to wear out a little sooner.... All things being equal, I would prefer the chains on the rear axle, but there can be good reasons to mount the chains on the front axle.
JMHO
--->Paul
2013 COACHMEN CATALINA TRAVEL TRAILER (A52472)
2013 COACHMEN...
Kubota BX23 4x4 Backhoe (A51573)
Kubota BX23 4x4...
2007 TRANSCRAFT 48X102 FLATBED (A52472)
2007 TRANSCRAFT...
2019 KOMATSU  D65 PXI 18 (A52472)
2019 KOMATSU D65...
2017 MITSUBISHI OUTLANDER SPORT (A52472)
2017 MITSUBISHI...
New/Unused 7ft 20 Drawer Stainless Steel Workbench (A51573)
New/Unused 7ft 20...
