L3410 hst.
Bent the right lower 3pt arm. Heated and hammered back
Pushed a hidden downed tree with the FEL while watching brush cutter. Tree bent about 10 foot then sprung back at me and came over the hood, smashed the fuel fill door, dented hood, side cover, bent the fel lever over, smashed the steering wheel back and down. The wheel hit my let and made a purple / blue from hip to ankle. (Yes, it hurt) Had to saw the tree to get out. Had the tree not hung up on the steering wheel, I wouldn't be typing.
Broke 3 sets of blades on the BrushBull 600. They vibrate a bit when 8-10 pounds of imbalance is induced...
Snapped the adjustable lift link (right side cranky thing). The threaded rod bent and snapped under load.
Right side floor board is buckled up where a stump came up after being mostly cut and pinned the HST in go mode. (FUN! -not-)
Tire chain caught a stump and got unhooked and partly fed into the cutter. Shooting links out like a machine gun.
Blew out 3 HST filters at -20F and colder, loosing 2-5 gal of fluid each time.
Moved a heavy backhoe dipper stick with the FEL and had it hang up on something and sway back into the front grill. Smashed the lower grill and screen. Smashed the battery holder on one side.
Ran a stick up into the trap door in front of the radiator screen, mangled it a bit. Hammer time to flatten.
Air filter sensor failed.
Aside from those and a few I'm probably not remembering, you can see I pretty much baby it.
