Footings - rocket science?
   / Footings - rocket science? #11
There is really no big secret to a good footing IF you know what one requires. You need to know how wide, the thickness, how deep and what re-bar. The answers are simple.
Go to the place you get your permit and ask. They will give you all of that as it applies to your area for free. Other than that it is just a matter of level and square. Even overdigging is not that big a deal. Don't try to back fill it but either use extra mud or fill with gravel well tamped.
Forms are another question. A simple rectangle other than the amount of bracing required is not that difficult but a complicated layout can be.
Form bracing. When you think you have enough, add more. You do not want them collapsing while pouring. I screwed that up on a simple 6"x4" perimeter pour on top of a patio pad. Took some fast scrampling and still wound up with a bulge. One extra brace would have prevented it.
Harry k
I agree on the over-engineering it thought. An extra $1k now in footing cost is well, well worth it.
I am awaiting a quote on the Amvic system. Interesting product. Integrac spec SAYS that there's is better. No shock there. I'm sure that Amvic says that theres is. I'll check out the link.
Oh, and yes, I meant pounds/sq ft. /forums/images/graemlins/blush.gif I've spent too much time ensuring the family vehicles have enough air in the tires lately given the fuel prices. /forums/images/graemlins/mad.gif /forums/images/graemlins/grin.gif
   / Footings - rocket science? #13
We have a builder in our town that will not build with anything else but ICF unless the customer absolutely wants wood. He has been using ICF for years and swears that wood houses can not be built to the same quality as an ICF house. He loves building with them because its easy and he really believes in the finished product. He has tried all sorts of ICF brands and is now settled on Phoenix systems. The open webbing allows for easy concrete flow, the price is good, and they manufacture them in many places including within 50 miles of us. No assembly is required and he says they are really strong. You may want to give them a look.
Eric
   / Footings - rocket science? #14
This is a long post, but it didn't take near as long to write this as it did for me to repair a foundation where corners were cut. If I can save someone that backache it's time well spent.
I'm not an expert, but I am experienced. In the last year I've repaired the foundation on my current house, and I've dug the foundation for the new house. Here's what I've learned with a bit of speculation thrown in.
We all know that some material supports a foundation better than others. My existing home sits on clay as does the new one. A fellow I talked with who is in the foundation repair business told me that clay is one of the worst of all materials to build on. Not so much because it is unable to support weight; it does that fairly well, but because of the unstable nature of clay. It's pretty much like building on a sponge. It expands when wet, and contracts when it dries out, therefore the support for the footers is constantly changing. OK, I can't change the material I'm building on, or the one my current home sits on; what did the expert tell me to do?
First off, he told me to keep clay wet in times of drought. That keeps it from shrinking and allowing areas to drop. He also recommended piers sunken deep into the soil in stategic areas for the footers to sit on. The piers should extend well beyond the clay down to bedrock. This would cost thousands of dollars, and was, of course, what he did for a living. I took his advice into consideration, but didn't go the piers route. I believe he is dead on with the moisture though. Most soil has some degree of organic material in it which expands and contracts with moisture. We should pay attention to keeping it damp, but not overdo it. We all know how much support we get from a mudhole.
When I dug the ditches for my new home's footers I went about a foot deeper than is normal for my area. Two reasons. First, to get beyond the disturbed soil resulting from stump removal. I took out over twenty stumps within the perimeter of the foundation before I started digging. We want undisturbed soil for the footers to sit on. Second reason was that the deeper we go, the less likely for the soil to react to a temporary drought. I figured that would be more stable soil. I did notice that the deeper soil was fairly moist even though the surface layer was dusty from a very dry fall. All that dry weather was over though as soon as I got most of the ditches dug. That's when the monsoons kicked in and dumped six inches of rain on my project. I had tons of mucky mess washed into the ditches and cave ins of the walls, but that's another story. I finally got to the point where I could put rebar in the ditches.
My code called for two number four bars at three inches of the bottom and at least three inches from the sides of the concrete. Code also called for the concrete to be at least sixteen inches wide and eight inches thick. That's what I've got on the current house and, remember, I've had to repair it. I wanted to do better, so I went with twenty four inch ditches for the perimeter walls, and twenty two inch for the interior piers. All ditches were continuous and connected to the perimeter wall. I also went with number five rebar and installed two rows stacked. Everyone who saw what I was doing thought I was crazy, until I explained my reasoning. For those interested enough to be still reading, here goes.
I understand that rebar is installed on the bottom side of the concrete to support the weight that is pushing straight down, and I believe it does a good job of this. The tensile strenghth of rebar is impressive, even if it does bend rather easy. If there is a soft spot in the supporting material under a straight stretch of concrete with rebar imbedded in it towards the bottom, and this soft spot allows the concrete to begin to sink, it results in an attempt to stretch the rebar on the bottom, not to bend it. Of course if the concrete settled very much it would bend the rebar, but we're already in trouble when that occurrs to any degree. The problem with the foundation on my house didn't happen in the middle of a long run though, it happened on a corner. Rebar on the bottom of concrete does very little to keep a corner from sagging because there's very little tendency for the rebar to stretch, but if you stack the rebar, now the rod on the top portion of the concrete would have to stretch considerably for the corner to sag. My two rods of rebar run three inches off the bottom and three inches down from the top, with a separation of four inches between the rods. That ought to help keep the concrete from sagging in the straight runs as well as in the vulnerable corners. At least it can't hurt.
For those interested in how I repaired my foundation, I'll make it short as I can. My house is a brick veneer with a crawlspace. The corner that settled caused the bricks to crack in a stair step design about twelve feet from the corner on two sides of the house. I dug out on the outside of the foundation until I was deep enough and wide enough to get a twenty ton jack under the corner. I sat the jack on a half in thick plate of steel for support and jacked until the jack quit lifting. It was working. The crack in the bricks was much smaller, but still there. I needed more lift and removed more dirt until I could get two more jacks under the foundation. Finally, with three jacks lifting to capacity, the foundation and the bricks were back where they belonged. Now to get it to stay there. I had a huge hole now to get access under the foundation and the hole extended out from the original foundation nearly thirty inches and under it more than a foot. I drilled into the old foundation in numerous points and inserted rebar leaving about two feet protruding. Then I filled the hole with concrete hoping the rebar would tie the new concrete to the original. After a year, so far, so good, but I had to go buy another jack. Those jacks are still down there imbedded in the concrete, but a small price to pay for a foundation that doesn't sag.
Trust me, more time, effort, and money dedicated to the foundation is well spent, if for nothing more than peace of mind.
Good luck with it.
Tom
   / Footings - rocket science? #15
Great story. I especially like that the jacks are still in the concrete.
It's stories like this that make me want to REALLY over engineer things. I have YET to live in a home (I'm on #5) that hasn't had some cracking in the foundation walls due to movement. It seems that everyone is trying to save a buck, but they end up costing the poor sap homeowner dearly in the end. I'm quite tempted to go 31" or maybe even more. Maybe I'm throwing money away, but I will be able to sleep. Thanks for the great story. I'll certainly keep it in mind as we get going here in a bit.
   / Footings - rocket science? #17
I've not actually seen it done, but that's exactly how I've read that the professionals repair slab foundations in this area; dig under, jack it up, and fill in with concrete leaving the jacks in place.
   / Footings - rocket science? #18
I guess that makes me a pro-jacker! Thanks Bird.
/forums/images/graemlins/grin.gifTom
   / Footings - rocket science? #19
When I did my foundation footings (sandy soil), I used 2x12s for the form, and dug it out a little on the inside. This gave me about 10 1/2" thick footings. I then placed them 24" apart for 10" thick walls, and put rebar on the inside and outside of the footings (Home Depot sells rebar stakes that support the rebar and I found these helpful; and good prices on 10' lengths of 1/2" rebar). Plus 7" plastic ties for lashing pieces together.
I'd suggest the thicker footings -- not much more $ but a lot stronger, especially if they're going to be 31" wide. You should order a copy of this book - lot's of valuable information.
Sounds like you'll need to step down your footing if you have a walkout section to maintain 42" depth.
I've ordered the book - thanks for the recommendation!
Ed
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52576)
2018 FREIGHTLINER...
FAE UML/SSL 150 VT BL HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
2008 Nautica International RIB 24ft Cat Boat with T/A Boat Trailer (A50324)
2008 Nautica...
2025 Swict 72in Bucket Skid Steer Attachment (A50322)
2025 Swict 72in...
2002 Ford Ranger Ext. Cab Pickup Truck (A50323)
2002 Ford Ranger...
Toro Workman 3200 Cart (RUNS) (A50774)
Toro Workman 3200...
