For those of you who have installed PTO extenders
   / For those of you who have installed PTO extenders #11
The snap ring holds the spring loaded sliding collar on, don't remove.
   / For those of you who have installed PTO extenders #12
Just so I understand the removal of this correctly,... All I have to do is slide the slip collar back and pull on the end of the spline and it should slide off the factory PTO, correct?
   / For those of you who have installed PTO extenders #13
That SHOULD be all there is to it. When you pull the collar back it should release balls that engage into a grove on the PTO shaft-I bet a dollar the balls are rusted and not moving back. You can try soaking repeatedly with a penetrating oil like WD40, or PB Blaster (my personal favorite) and then tapping with a brass hammer or block of wood.
Last resort would be to remove that snap ring and slide the collar back-But you risk the possibility of flying springs and never getting it back together!
   / For those of you who have installed PTO extenders #14
Thanks to all who posted replies so quickly.... I did finally get it off, and yes, the little balls that are supposed to retract were sticking, and that was what was preventing it from sliding off. Great feeling knowing how stuff works.
2019 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2019 HarbinGer V3...
2010 CATERPILLAR D6N LGP DOZER (A51406)
2010 CATERPILLAR...
2018 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A52705)
2018 CATERPILLAR...
5TH WHEEL HITCH (A53843)
5TH WHEEL HITCH...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
Pair 2 - ST225/75R15 radial trailer (A53421)
Pair 2 -...
