For those of you who think the L3400 has a weak loader!!
   / For those of you who think the L3400 has a weak loader!!
I used to easily lift my rear tires off the ground, even with a heavy counterweight. Then I got my rears filled with 1100lbs of ballast, and with no counterweight I can still lift my rears off the ground, however, with a 1400lb implement on the back, in combination with 1100lbs of ballast, I can use the full capability of my loader now-all without worrying about the rears coming up. It's important that the needed lift capacity of the job at hand is properly matched to the ballast on the back, or rather, vice versa.
LD, I don't remember if you mentioned it or not, but are your rears filled with ballast? I would take a guess that they are not, but of course I could be wrong. It's not surprising that the rears can come off the ground with 1,100lbs of rear implement on the back, and no ballast in the tires. However if your rears are filled with close to 1k lbs of fluid AND you have the brush hog on the back, and your still lifting the rears off the ground, then I'm going to agree with you and say that your loader is very well matched (if not a little large) for your tractor.
Yes rears are filled. But it isnt even close to 1k. I cant remember for sure, but I think I only got like 20-21 gallons of WW fluid in each tire. So ~400# total. I have the 11.2-24 R1's. No doubt industrials would hold more.
GMC 2500HD 4wd Service Truck (A56438)
GMC 2500HD 4wd...
Krause Dominator 4850-18ft (A56438)
Krause Dominator...
2025 Stump/ Trench Bucket Mini Skid Steer Attachment (A56857)
2025 Stump/ Trench...
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A59575)
2020 INTERNATIONAL...
Kubota L4701 (A53317)
2016 Textron T/A 15 Ton Flatbed Equipment Trailer (A59230)
2016 Textron T/A...
