the old grind
Elite Member
- Joined
- Jul 21, 2012
- Messages
- 4,412
- Location
- Mid-Michigan
- Tractor
- NH T-1520 HST, NH TC33DA HST, Case DX26 HST, .Terramite T5C, . NH L785
how you have it... it can be done and can work. as others have said keep it filtered. and change the filters as needed / when needed.
would suggest adding 2 vents. into the return duct work. 1 near ceiling, and 1 near floor. so you can open/close the vents pending if winter / summer.
if the ceiling (between basement and main floor) is not insulated. just circulating warm air down stairs with say a floor fan. so the air down stairs rotates in a large vortex / whirl pool like current. down stairs. can allow the heat to move around and go right up through the ceiling. ..
For years, I used a small (10") fan on the basement floor angled up at 45^ or so to move air around 24/7/365. It did wonders to even out the temps and reduce rusting in corners that were no longer damp-ish in moderate weather. For whatever reason, it helped o'all comfort both upstairs and down (open stairway) by the increased circulation and basement heat spread more uniformly beneath the upper floor.
Be sure there are adequate steps taken to equalize air pressure outside to inside either by an unobstructed inlet close to the wood furn or a 'cold air package' fitted to it. IMO there's never too much filtering or circulation, up to the point where one's hat is blown off.
