Ford 101 Bottom Plow
   / Ford 101 Bottom Plow #1
Tucker dog
Allis Chalmers D 310
I have a Ford 101 bottom plow and the front plow has been rotated around. I have moved it back in place but cant get it to lock in place. I havent been able to find a manual for this either. Does anyone know how to fix this?
   / Ford 101 Bottom Plow #2
It probably has a shear pin that has sheared. The remnants of the old broken pin sometimes remains and has to be tapped out with a punch. If yours is a shear pin model (versus a spring latch type) it will have a hole in the housing that the pin slides into. I use grade 8 bolts (I think 5/16") for shears. Simply slide a new one in after rotating the bottom back into place where the holes line up. If yours is a spring latch model, the latching mechanism will need to be openned up and inspected.
   / Ford 101 Bottom Plow #3
Try this:
CASE 6591 T/A PORTABLE POWER UNIT (A51247)
CASE 6591 T/A...
2011 DOOSAN G25KW GENERATOR (A53843)
2011 DOOSAN G25KW...
2013 East Manufacturing 45ft T/A Walking Floor Trailer (A53422)
2013 East...
2017 Ford F-550 Crew Cab Enclosed Service Truck with Liftgate (A53422)
2017 Ford F-550...
2019 MDB FM180 FINISHING MOWER (A51247)
2019 MDB FM180...
