Ford 1220 Starts 1st time, shut it off and won't start again.
   / Ford 1220 Starts 1st time, shut it off and won't start again. #1
fishnfarm
City, MO
Ford 1220
Hello. First time poster on here. I have a little Ford 1220 4x4 w/ loader. It will start up fine the first time and run for as long as you want but when you shut it off, it doesn't start again until it sits for a long time. Where should I start? Any help is much appreciated.
   / Ford 1220 Starts 1st time, shut it off and won't start again. #2
When you say "...it doesn't start again....", do you mean the starter wont turn the engine over OR the starter does turn the engine but it won't start and run? The former is a problem with the starter electrical system and the later may be a problem with the fuel delivery system. You have to be more specific on these forums to get help because most of us are not mind readers.
Sorry about that. The starter does turn the engine over but it will not start and run.
   / Ford 1220 Starts 1st time, shut it off and won't start again. #4
If you can't hear the fuel solenoid open (click) when you turn the key, the solenoid, or more likely, the 'open' signal to the solenoid may be weak. One way to check is to put 12V on the fuel solenoid (using Powerpack or jumber cables) and try to crank.
KUBOTA M7040 TRACTOR (A51406)
KUBOTA M7040...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A51219)
2019 INTERNATIONAL...
2022 Case TR340B Skidloader (RIDE AND DRIVE) (A50774)
2022 Case TR340B...
2013 VERMEER RTX1250 RIDE ON TRACTOR (A51242)
2013 VERMEER...
2021 Interstate Tiltbed 40TDL 24 Ton T/A Flatbed Trailer (A49461)
2021 Interstate...
2015 CATERPILLAR 305E2 CR EXCAVATOR (A51242)
2015 CATERPILLAR...
