ford 1220
   / ford 1220 #1
dixon430
i have a ford 1220 3 cyl. diesel, i had a friend rebuild it and it starts and runs fine but when it gets hot it is hard to start.injector pump and injectors were rebiult. does anyone have any ideas. thanks
   / ford 1220 #2
When you say hard to start do you mean it doesn't want to crank over or it cranks fine but wont start.
   / ford 1220 #3
Ditto on the crank/ no start question.
if it cranks over fine.. but won't catch next time, loosen the lines at the injectors like you are bleeding it and see if one or more have a little air.
Could be an injector(s) leaking.. or the pump itself leaking on an individual injector line.
in any case.. crak line.. bleed, tighten line.. and see if it fires up fine. if so.. pump may not have been gone thru correctly.. or injectors were not rebuilt good.
Soundguy
   / ford 1220 #4
When you crack the line, do you then crank the engine to bleed it?
Bob
   / ford 1220 #5
Yes.. unless you have a diesel engine with a manual fuel plunger for priming.. like might be found on many of the chinese tractors. even still.. I'm not sure if those can prime past the pump.. or just 'to ' the pump. Cranking over may still be the only way to bleed the lines fromt he pump to the injector.. even if you had a method like a plunger to prime from the tank to the pump.. etc.
As a side thought.. The fellow should check to see if he is 'making' any oil.. also.. if he has a oil lubed pump with it's own sump. he should check it to see if the lube oil has not been thinned out from diesel.. etc.
Soundguy
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2016 Ford Escape 4WD SUV (A50324)
2016 Ford Escape...
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
Greenworks Commercial 82V CZ60R Zero-Turn Mower- BRAND NEW, NEVER USED (A52748)
Greenworks...
PLEASE VIEW ALL PICTURES!! (A50775)
PLEASE VIEW ALL...
