ford 1510 3 pt hitch drops
   / ford 1510 3 pt hitch drops #1
spiter23
ford 1510
My 1986 ford 1510 has all of a sudden developed a problem. When the engine is turned off, the 3pt hitch arms fall. I have turned the knob in front of & just below the seat, but this has had no effect. Any ideas on what I should check? Thanks, Greg
   / ford 1510 3 pt hitch drops #2
My 1710 did the same thing,change out your hydraulic fluid.If your tractor sets outside all the time condensation forms in the transmission over time.Check your fluid to see if it has a milky color.This is a good sign that water is in your transmission. /forums/images/graemlins/smirk.gif
   / ford 1510 3 pt hitch drops #3
Also when you drain your oil out of your transmission dont forget to drain out your rear end.They share the same sump but have to drain them separatly. I dont think not filling up the filter is a problem when you start the engine up it fills the filter first. /forums/images/graemlins/smirk.gif
2017 Schulte FX107 84in Rotary Cutter Attachment (A50322)
2017 Schulte FX107...
12' Disc Harrow (A50120)
12' Disc Harrow...
New/Unused 7ft 20 Drawer Stainless Steel Workbench (A51573)
New/Unused 7ft 20...
KODIAK 10' HD ROTARY MOWER (A51406)
KODIAK 10' HD...
2012 Ford F-150 Crew Cab Pickup Truck (A50323)
2012 Ford F-150...
2015 PETERBILT 567 TRI-AXLE (A52472)
2015 PETERBILT 567...
