ford 1510 3 pt hitch drops
   / ford 1510 3 pt hitch drops #1
spiter23
ford 1510
My 1986 ford 1510 has all of a sudden developed a problem. When the engine is turned off, the 3pt hitch arms fall. I have turned the knob in front of & just below the seat, but this has had no effect. Any ideas on what I should check? Thanks, Greg
   / ford 1510 3 pt hitch drops #2
My 1710 did the same thing,change out your hydraulic fluid.If your tractor sets outside all the time condensation forms in the transmission over time.Check your fluid to see if it has a milky color.This is a good sign that water is in your transmission. /forums/images/graemlins/smirk.gif
   / ford 1510 3 pt hitch drops #3
Also when you drain your oil out of your transmission dont forget to drain out your rear end.They share the same sump but have to drain them separatly. I dont think not filling up the filter is a problem when you start the engine up it fills the filter first. /forums/images/graemlins/smirk.gif
2008 JOHN DEERE 6330 LOT NUMBER 98 (A53084)
2008 JOHN DEERE...
ASSET DESCRIPTIONS & CONDITION (A52576)
ASSET DESCRIPTIONS...
2020 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2020 CHEVROLET...
2020 Nissan Rogue SUV (A51694)
2020 Nissan Rogue...
Kinkaid 1200 LS-PH Towable Hydroseeder (A51691)
Kinkaid 1200 LS-PH...
2018 Ford Explorer AWD SUV (A51694)
2018 Ford Explorer...
