ford 1600
   / ford 1600 #1
bassman7225
ford 1600
can anybody tell me where to find information on adding a hyraulic remote to a ford 1600? I am putting a 60" front mount snowblower on and need to add hydraulic controls for the lift and chute turn. Any info would be greatly appreciated.
   / ford 1600 #2
Here is some tractor data for you.
Fight now, this is what you have.
Hydraulics:
Capacity: 2.6 gal [9.8 L]
Pressure: 1421 psi [98.0 bar]
Total flow: 4.2 gpm [15.9 lpm]
TractorData.com Ford 1600 tractor information
If all you have now is the pump and 3pt, you could add a two spool valve to your hyd. Run the line from the pump to the IN port of your new valve with PB and the OUT port goes to tank.
You could go with a PTO pump, reservoir and valve .
2013 BMW 528i Sedan (A50324)
2013 BMW 528i...
10ft Fork Extensions (A50322)
10ft Fork...
2014 Volkswagen Jetta Sedan (A50324)
2014 Volkswagen...
2016 Dodge Caravan Van (A50324)
2016 Dodge Caravan...
Skid Steer Gravel Leveler (A50515)
Skid Steer Gravel...
2 Axle Deckover Trailer (A50774)
2 Axle Deckover...
