Ford 1620: Opinions Please
   / Ford 1620: Opinions Please #1
Tom K---Semper Fi
Western Mass, USA
Kubota B5200
I've been shopping for a used tractor for a couple of months now, and came upon a 1995 Ford 1620. It has very low hours considering the year and is in absolutely immaculate condition. I don't know anything about Ford tractors :confused: so I'd like to hear from any 1620 owners about reliability, any problems they've had, and any known issues. I'd also like to hear from any Ford owners on how they feel about Ford in general.
I'm looking forward to your help.
Thanks,
Tom
   / Ford 1620: Opinions Please #2
Tom, I dont know about the 1620 but my 1900 is a tank. The only problems I have had were from abuse. These tractors will amaze you with what you can do with them. I would make sure to get 4wd.
Bill
   / Ford 1620: Opinions Please #3
I don't have 1620 but size wise and PTO hp and weight is comparable to my 1700. With 3 cylinder engine and better hydraulic would certainly be an upgrade. I don't think you can go wrong as they are robust, well engineerd and easy to maintain of course if mechanically sound. I'd jump on it if the price is right and is in good working condition.
jc
Just FYI if you looking for more info:
TractorData.com Ford 1620 tractor information
   / Ford 1620: Opinions Please #4
I don't think you would be disappointed one bit. Plus there are some very knowledgeable Ford guys in this forum who really go out of there way to help.
   / Ford 1620: Opinions Please #5
the 20 series generally has ergonomic upgrades over the 00 and 10 series.. my 1920 was a cadilac of a ride compaired to a more spartain 1910.. etc.
soundguy
   / Ford 1620: Opinions Please #6
Tom,
We had a 1620 hydro, loader,4wd, was a very good tractor,easy on fuel,very easy to operate,easy ldr on\off and had good luck w it. Only issue w the 20 series was the hood is flimsy,would dent easily.
P
   / Ford 1620: Opinions Please #7
Do some homework and make sure mechanical parts are available. Sooner or later you may need a head, crankshaft, or transmission parts. Some of these older models are not supported by a current parts supply system. You may be better off spending a few more dollars to get something current. Trust me.... theres nothing like a 3k boat anchor.
   / Ford 1620: Opinions Please #8
I've got a 1996 1620 with 600 hrs on it and I love it.
It's the right size for what I am doing. I needed maneuverability in my tight wooded area and the 1620 is smaller than a 1920 that I was originally looking at. It's never lacked for power however sometimes I would like more lift capacity that the 1920 or 2120 has. I've moved about 200 yards of dirt, pulled big logs, lots of firewood, moved lots of patio pavers, brush hogged fields and more. It runs my 5 ft brush hog fine, has adequate lift capacity (full buckets of moist sand). I've put my friends 3 pt mounted woods backhoe on it and that worked well. It dug trenches and ripped out stumps for me.
I put chains on the turf tires as the plane turf's don't bite at all in the snow. It would pull my 5 ft back blade in the winter on the snow without the chains, but if I had to use the bucket to move large piles of snow it had poor traction even in 4wd (without the chains). With the chains I pull 18" dia by 40 ft logs up snowy hills in 12 to 20" of snow. It's a tank with the chains on it. Yet the turfs are friendly to the grass in the summer. I've recently added a 7.5 ft truck style snow blade to the back and it plows snow like a champ.
The Hydro drive is nice. I have a bad left knee and it was hard using my friends 1710 with a clutch so a hydro was a must have for me. With the 1620's hydro and the high, medium, low selections you can find the right ratio for the work that you are doing. And it's so nice when you are moving soil to and fro not to have to clutch in several hundred times in a day like my friends 1710. The control placement seems nicely laid out and you don't get tired of being in the seat. It also sips fuel and starts well at 10 degrees F even without a block heater.
The only down sides are trivial. The headlights are not that bright and the ROPS does not fold. The ROPS on my 1620 is about 1" taller then my garage opening unless I keep the rear tire pressure on the low side. But that isn't an issue unless I have the backhoe on it, which is rare, and then you need to pump the tires up anyway due to the weight of the backhoe. The ground clearance is good but the large low pressure hydro filter sticks down. I dented it pretty good on a branch once when I was deep in the woods and it loosened and started to leak a bit. I could not figure out why they didn't place that filter out of harms way. It dented but didn't get a hole in it or leak much and I'm just a bit more careful running over big piles of branches. I've dropped stuff on the hood and it didn't dent to easy (similar to my friends 1710 I would say).
I've had no mechanical problems with it except the zerks on the bottom of the bucket pins tend to plug up and grease will not flow into them. I remove and replace them about every 2 years (a 10 minute job). The are just in a bad spot and get muddy and full of water in my swamp.
I am really happy with it.
Thanks for all the information guys (or gals). I've decided to buy the 1620 that I found, but I can't pick it up until next Saturday :(. I hope we don't have any major storms before then. I'd hate to miss out on the fun :).
Thanks,
Tom
   / Ford 1620: Opinions Please #10
Stuartshomepc,
Great write up! I love my Ford also because it is sized for what I usually do.
After reading yours I want to go buy a 1610 / 1620!
   / Ford 1620: Opinions Please #11
've had my 1620 for 5 years now. Bought it used to improve and maintain the ten acre wooded lot around my house. Replaced the turf tires and wheels with a set of ags and couldn't be happier with with it. The hydro makes using the loader a breeze and the small size is perfect for dodging between the trees, even with the loader attached. I can take the loader off and put it back on without help and it has plenty of lift for my 1/2 yard or so bucket. Likewise the PTO power is plenty for my 5' mower, post hole digger and DRpower chipper. It also handled a rented power hoe I used to regrade my gravel driveway. I've always been a John Deere fan, but this little beauty is great. I'll be moving soon and won't have a use for it so I have to sell it. I will be very sorry to see it go.
   / Ford 1620: Opinions Please #12
lhealy,
I have a Ford 1720 that I would like to replace the turfs with ags.Where did you get the wheels for the ags?From a dealer?I was quoted a price of about $ 1600.00 just for the wheels from my local New Holland dealer.That seemed a bit steep to me.
   / Ford 1620: Opinions Please #13
lhealy,
The 1720 was arguably one of the most popular Ford models sold in the last decade or so of Ford tractor production as it was used by several commercial, public and private owners. As such, you may have some luck in finding a set of wheels. Unfortuneately, you may have to do a little maintenance on them as folks often had the tires loaded with chloride!
   / Ford 1620: Opinions Please #14
I know this is an old thread but I just wanted to thank Stuart for his great response. It's given me some good direction about "features" I want to add to my 1620. We just got the tractor and writeups like that are priceless.
2020 CATERPILLAR 299D3 SKID STEER (A60429)
2020 CATERPILLAR...
2022 BOBCAT T770 SKID STEER (A60429)
2022 BOBCAT T770...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
2004 Toyota Camry Sedan (A59231)
2004 Toyota Camry...
Hays LT1 Tender (A61307)
Hays LT1 Tender...
2005 BOBCAT T300 SKID STEER (A60429)
2005 BOBCAT T300...
