Ford 1700 4wd
   / Ford 1700 4wd #11
It's always nice to have another MAINAH on TBN,/w3tcompact/icons/laugh.gif /w3tcompact/icons/laugh.gif /w3tcompact/icons/laugh.gif
   / Ford 1700 4wd
Here I am sitting with my head full of things to make for my 1700, shuffling through a Boomer brochure every time one of you guys posts, so I can see whatcha got.
I'm going to repost this as Ford 1700 4wd over on NH own/operate, because I got a ton of other stuff to talk about, and I just figured out this isn't really the right place. In fact/ maybe customization is better. Thanks for all the kind words and encouragement.
   / Ford 1700 4wd
Oh, BTW - here 'tis
   / Ford 1700 4wd #17
Wow Knucklehead, looks good for $6000. You're making me look bad with my wife. We spent twice that money. I hope she doesn't see your buy. /w3tcompact/icons/wink.gif Kent
   / Ford 1700 4wd
Yeah, Kent, but you got a real nice tractor. I spent an hour trying the the cutter, and then dropped it and spread 16 yards of gravel, and I got Popeye arms from the manual steering. I'll learn to go easier. After I got it washed down, I went around tightening every bolt I could find. The exhaust was loose, the loader mounts were loose /w3tcompact/icons/shocked.gif, the front steel frame that bolts to the block and supports the front axle, radiator, and front of the loader had 4 out of 12 bolts loose /w3tcompact/icons/shocked.gif/w3tcompact/icons/shocked.gif. I started a list, which includes spacing out the fenders to cover the tires (which will let me install a tool box), relocating the lights up onto the ROPS, making a cheap n' dirty canopy, making a brush guard and maybe a belly pan. Got a modified truck snowplow rig from my Dad's old Kubota that needs to be cleaned up and installed on a handy little front mount my brother made, and then we'll look at the implements that are arranged along the rock wall back home. Pix to follow on appropriate forum.
ITEM LOCATION LOT NUMBER 3 (A53084)
ITEM LOCATION LOT...
2016 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2016 Ford F-550...
JLG 1930ES ELECTRIC SCISSOR MAN LIFT (A51246)
JLG 1930ES...
1987 LANDALL 48ft Hydraulic Slide Axle T/A Drop Deck Trailer (A51692)
1987 LANDALL 48ft...
toro turf sweeper (A50324)
toro turf sweeper...
26ft x 24ft Metal Building (A51573)
26ft x 24ft Metal...
