JC-jetro
Elite Member
Nice, that was quick.:thumbsup: It is so much better to take a big problem without adding further to it and divide it to simpler components. Start from the very bottom and build a case. Any how , glad it was quick and painless as there is plenty of potential to dork up a perfectly good system with all good intentions.
-about 2100 psi is okay. As the pump gets older pumping efficiency might go down to wear and tear. Poppet stuck open either by some contaminant or did not seat right due to deadheading as it forces the relif valve to jump off the seat, chatter and bypass.
Q1- yes. Mine is about 2200 pressure, that pressure is achieved at rated rpm for pto, so if you idle you will read a lower pressure. it is directly proportional to pump speed.
Q2- yes, and yes
and works just the same for me too.
Q3- not with first start. now think about it, glow plug has no moving part, 10 seconds of preheat in the summer and starting on the first try is always always better as wear and tear is minimized on the starter. in winter I give it 20 second, warmer I give it less and my tractor 95% of time starts on the first crank. Save your starter and always always preheat unless the tractor is already hot.
JC,
Q2- yes, and yes
JC,
JC: YOU SIR ARE A SAVIOR!!
I checked the fluid level and it was fine.
Connected a 0- 140 PSI pressure gauge and ran it- had zero PSI as I stated earlier.
Pulled out the pressure relief valve component, and started the tractor for 6 seconds, as fluid went all over. NOTE: I'm glad I had put down plastic sheeting for this test just in case.
Reassembled the valve. At first I started the valve back into place, but was concerned the poppet might fall off the spring into which it fits. So I took it out and put some grease on it to secure it in place while screwing it in.
Started the tractor- operated perfectly.
I then performed the pressure test per the manual, and had 1900 PSI, and adjusted the pressure relief valve to 2100 per the Ford manual value of 2133 +/- 71 PSI. So I'm assuming the poppet valve was stuck out of position as you surmised. Still would have thought would have had some pressure, not zero, but that wasn't the case.
Q1. My 'EDIT' statement above is incorrect, right? What approx. pressure would I see if I put the gauge at the return fitting at the tranny/control valve? Would it be near zero or?
Q2. For the system I drew above, a properly operating pressure relief valve will protect the hyd. pump from people like me, right?
Q3. Will your 1700 start on a 60 degree day without using the pre-heat?
Thanks very much for help!- Dean
