JC-jetro
Elite Member
Thanks, that would work for sure. Your hitch lever is alot different than mine, I have a straight bar running parrallel to the ground from the control lever to the rear arm. The rod is a linkage rod that is about 6" long. I tried to find a picture of it on messicks but no luck.
There is a castle nut where the rod goes to top diffy cover. spool valve is immediately inside. If you notice you have several washers that act as friction washers, don't need to be to tight. Too lose and the handle move and too tight and you can move it. on some rigs some washer might be leather to afford application of gradual tension with metal washers on either side for protection of leather.
JC,
The
